August 11, 2026, 03:01:27 AM
How To: Rear Sway Bar.
Topic: How To: Rear Sway Bar. (Read 76139 times)
mnkyman
Re: How To: Rear Sway Bar.
Reply #30 on:
April 24, 2009, 06:53:28 PM »
I have a question for yall. So suleman and I installed my swaybar last summer. We used grease from brake check (suleman's job) on the bushings and it worked great. Well fast forward to winter time and I can start hearing the sway bar rubbing against the bushings (or possibly the exhaust hanger, but I didn't hear that before so im assuming its the first). Any special grease yall would recommend that can withstand some time
Sam
-|- 2006 I4 Sedan SE
Reply #31 on:
April 24, 2009, 10:36:02 PM »
Front sway bar is a motherfucker if you don't have the right tools and equipment. If you are not comfortable with lowering the front lower sub frame, then you should pay someone else to do this for you.
I have car stands, and a large jack ... what else would I need?
Am I getting into something dangerous here?
Reply #32 on:
April 24, 2009, 11:10:09 PM »
Yes, it is something you should not do in your driveway. It is best to do at a shop that has lifts to do the front sway bar. The rear on the other hand can be down in the comfort of your garage or driveway. What Tim says is true on the front sway bar. It is a pain in the ass to install. I have done the install, and if you don't have a lift or proper tools, it can and will be a dangerous install.
Reply #33 on:
May 21, 2009, 09:40:53 PM »
Anyone got the part number for the end links?
I am thinking mine might be seized because of age...
Reply #34 on:
May 21, 2009, 10:28:38 PM »
hondaautomotiveparts.com + a little time searchng = your answer
Reply #35 on:
May 21, 2009, 10:46:43 PM »
http://www.hondaautomotiveparts.com/aut ... +LOWER+ARM
I looked here, wasn't exactly sure which exact piece is the endlink for the sway
Are they these?
2324177 008 1 LINK, R. RR. STABILIZER
2324178 009 1 LINK, L. RR. STABILIZER
Reply #36 on:
May 21, 2009, 10:57:12 PM »
Yes.
Reply #37 on:
June 06, 2009, 05:03:08 PM »
Got both my sways installed.. didn't need endlinks thankfully!
Car feels so planted now
pbplayer257
Reply #38 on:
August 10, 2010, 03:41:44 PM »
Should I buy an acura tl rear sway bar that corrolates with th same year vehicle as mine? I have an 05 coupe, so should I buy the 05 tl rear sway bar? Or does the year of the sway bar not make a difference? Also if newer model sway bars will fit my vehicle will there be an advantage to having an 07 rsb over an 05.
Reply #39 on:
August 10, 2010, 03:47:47 PM »
Different years can represent differance in size.
Reply #40 on:
August 10, 2010, 08:19:59 PM »
I got the 07 TL-S RSB. I have an 03. So, like Mike said I think it just depends on what size you want.
Reply #41 on:
August 10, 2010, 11:00:27 PM »
04-08 Base TL - 17mm
04-08 TL-S and Type S - 20mm
Stock Accord is 14mm
pbplayer257
Reply #42 on:
August 14, 2010, 12:21:44 AM »
thanks for clearing that up, and is $70 too much to spend on the tl 20mm rsb. The dealer i went to wanted about 70 for rsb, bushings and what not. I looked online and it was about $60 shipped for everything. I just want to make sure im getting a good deal
Reply #43 on:
August 14, 2010, 09:09:08 AM »
Quote from: pbplayer257 on August 14, 2010, 12:21:44 AM
70 to high when i got mines i payed 50 from my dealer and they sent me 2 rear ones i have a extra one and can make you a better deal if you in the nyc area. installing the front will be my next mod when i find a decent mechanic
pbplayer257
Reply #44 on:
August 14, 2010, 08:29:52 PM »
well im in the jersey area and i dont go down to nyc that often, but for a good price i might be up for a hike
pm me
