April 21, 2026, 02:29:17 PM
How To: Rear Sway Bar.
Topic: How To: Rear Sway Bar. (Read 72991 times)
bian.yy
Re: How To: Rear Sway Bar.
Reply #60 on:
December 28, 2015, 03:14:13 AM »
Quote from: timot_one on April 24, 2009, 04:47:09 PM
Front sway bar is a motherfucker if you don't have the right tools and equipment. If you are not comfortable with lowering the front lower sub frame, then you should pay someone else to do this for you.
Hi tim, do you have a procedure how to replace front one, that day I lift up the chassis and saw I need to lower the subframe before replacing the bar. I feel the technician is not that confident with this job. In work shop manual the instruction is splitte to 2 portions, some in 'replace subframe', the others is in how to change front sway bar, there is not an exact description of this special job. I dont think all subframe bolts need to be uninstalled as the manual stated in "replace subframe". And then, I'm not sure if marking and re-align are quite difficult or not, I checked the technicina, it seems he has no sense on this point, I need to know which bolt will be uninstalled and replaced by new ones firstly.
Reply #61 on:
December 28, 2015, 09:24:28 AM »
Neuspeed has the instructions on their website. It's not extremely complicated to do the front, it's just difficult to get the front sway bar out. You can reuse the front sub frame bolts if you want. I've remove my sub frame a few times and used the bolts again.
bian.yy
Reply #62 on:
December 29, 2015, 01:06:45 AM »
Quote from: timot_one on December 28, 2015, 09:24:28 AM
Hi Tim, what is the reason to mark on subframe when uninstalling rear bracket. I saw that bracket connecting between sub frame and frame.
Reply #63 on:
December 29, 2015, 10:16:47 AM »
No clue.
