June 19, 2026, 10:57:59 AM
ECU, EMS, & Tuning
The K-Pro Thread
Topic: The K-Pro Thread (Read 182790 times)
neoryan7
Re: The K-Pro Thread
Reply #90 on:
September 01, 2009, 05:29:49 PM »
Hey Mike, I figured out the whole AC thing today. Works like stock. The thing is cham didn't have very important AC connections hooked up.
You mention that the fan was blowing hot air right like the AC wasnt engaging or something. Well, its because Cham didn't hook up the fan for the stock ecu.
Also, now it idles up like normal too. Cham also did not connect the Alternator signal to the Stock ecu.
PM me if you want sepecifics. I can probably explain better on the phone if you think my explinations are too vague online.
Reply #91 on:
September 01, 2009, 05:43:48 PM »
I wish I knew more about what Cham did with my harness, because my a/c works fine.
Reply #92 on:
September 01, 2009, 07:28:36 PM »
Quote from: "thisaznboi88"
NICE!!!! RSX Gauge? Where do I sign up lol?
x2....dam that would look so hot
k24cm_5
Reply #93 on:
September 02, 2009, 03:10:38 AM »
is this working with the dbw.
Reply #94 on:
September 02, 2009, 04:54:15 AM »
No its Cable
Reply #95 on:
September 02, 2009, 08:17:36 AM »
What's going to run your HVAC?
Reply #96 on:
September 02, 2009, 12:44:06 PM »
All specifics will be posted Friday or Saturday by Paul or I when its finished. I will say swapping to a Cable TB was cheaper than anticipated. All I needed was a Cable TB and a lil modification. Got a Type-S TB for $70 and sensors for like $40. Not a bad deal at all. Other than that its still running the TSX IM just modified by Paul for the Type-S TB.
Initial impressions of the Cable TB, its incredibly responsive compared to the DBWs hesitation when you hammer it. Ill post pics and vids soon
Last Edit: September 03, 2009, 11:20:36 AM by BliNx197
Reply #97 on:
September 02, 2009, 01:38:12 PM »
The RSX ECU and MCU.......
For all intent purposes it will be a Kpro'ed 03 RSX-S, the only functional loss will be TCS, ABS will still function happily.
Reply #98 on:
September 02, 2009, 02:27:52 PM »
Sounds like a damn good solution. Glad you guys got that shit figured out. I can't wait to come down and check it out some time.
k24cm_5
Reply #99 on:
September 08, 2009, 03:00:21 AM »
ok.i need someone to help me out with swap of the tb from dbw to cable.im also interested in doing the kpro as well.can someone PM please
im trying to build a all motor as well i have all the internals to build it but i need to swap this out so i can make the kpro work
Reply #100 on:
September 08, 2009, 06:21:09 AM »
To do the DBW to cable TB there are a couple things needed.
1) eaither get the throttle cable from a 03-04 accord or like I did you have to shorten the outer casing about 1.5", if I had to do it again I would have just ordered the cable.
2) eaither use the correct intake for the cable TB (including RSX intake) or fab a adaptor and weld it on the existing intake.
The entire conversion to run KPro directly needs the following.
02-03 KPro'ed ECU
02-03 RSX-S engine harness
I used part of a extension harness to make a adaptor for the ECU E connector to the accord body connector
A DPDT relay to drive AC functions
RSX gauge cluster (I got a used rsx dash harness for $50 and took the connectors from that and the stock cluster to make a conversion harness to go from the accord to the RSX cluster)
A dakota digital signal modifier for VSS, the RSX cluster takes it speedo signal from the VSS which on the RSX is mounted near the diff and only pulses 4 times per tire revolution, the TSX and Accord use a counter shaft sensor which pulses at 100 times per revolution (yeah 140mph at idle in 1st gear).
The fuel level sender from a RSX to get proper readings for fuel level in the tank.
Reply #101 on:
September 08, 2009, 08:05:05 AM »
Paul, were you able to keep the cruise control when you switched from DBC to DBW? Did you completely remove the Accord ECU, or did you keep it to run the HVAC?
Reply #102 on:
September 08, 2009, 08:45:08 AM »
^Cruise is out for now, but can be put in from the RSX.
The stock Accord ECU is completely out and the RSX-X ecu put in it's place, HVAC is run by the RSX logic and a added relay.
Again at the end of the day this is a Accord with the brain of a 03 RSX-S.
Reply #103 on:
September 08, 2009, 09:06:15 AM »
Nice work Paul. I like that you killed off the dual ECU option and went with the single ECU instead. The way Hondata should have done to begin with. Nice work. I may look into this option in the future as opposed to the dual setup. Think it's possible?
Reply #104 on:
September 08, 2009, 09:19:29 AM »
Oh it is possible, but like I said way back, this is not nearly as plug and play as the dual ECU and is more costly with the additional wiring and sensors, but in the end is much cleaner looking and operating.
