November 07, 2026, 06:46:36 PM
ECU, EMS, & Tuning
The K-Pro Thread
Topic: The K-Pro Thread (Read 194020 times)
Re: The K-Pro Thread
Reply #60 on:
June 30, 2009, 12:49:01 AM »
I forgot to mention that this modification only took about an hour to complete, including running the wire for the LED.
neoryan7
Reply #61 on:
July 01, 2009, 03:37:39 AM »
Aww no diy pics? So basically you stuck another LED into the same "cell" as the MIL?
Reply #62 on:
July 01, 2009, 11:24:47 AM »
Yeah, I know. I didn't take any pics. It was one of those last minute mods that I was just doing because I had a few hours to kill while waiting for Cham to show up. You are correct though. I basically covered the OEM LED and put the KPro CEL LED in the same "cell" as the OEM CEL. It's all fairly simple when you get everything apart and see what you're dealing with. I may take things apart to try and take pics for you guys if I have any time.
k24cm_5
Reply #63 on:
July 09, 2009, 02:34:41 PM »
would i be able to switch my dbw to a cable tb? and i can do that would i be able to use the kpro or its not that easy
Reply #64 on:
July 09, 2009, 05:51:38 PM »
I would wait a bit. I know Cham is trying to try and adapt his harness for the K24A8's.
hondaguy214
Reply #65 on:
July 09, 2009, 06:09:41 PM »
tim that sunday that im up there cham can get a go at my car. i also was wondering if you would do something for me. while im up there.
NECM
SQUAD
#6
k24cm_5
Reply #66 on:
July 09, 2009, 07:31:00 PM »
ok im going to just wait them
Reply #67 on:
July 14, 2009, 09:01:32 AM »
just FYI
http://www.gen7accord.net/forum/topics/fs-kpro-harness
Reply #68 on:
July 17, 2009, 04:37:48 PM »
accord is wideband OE Type - Exact Fit; 4 Wire; Wideband A/F; Upstream Sensor; Check / Replace Interval: 100,000 Miles
xodus
Reply #69 on:
July 17, 2009, 05:35:22 PM »
for the o2 sensor not sure if its a wideband this should help .. being that its an oe part... that should mean that the denso would be a wide band.. and could save people money
Bosch Oxygen Sensor
Part No. 15400
LS2 GTO =)
Reply #70 on:
August 04, 2009, 02:37:42 PM »
No updates on Kpro on k24a8 yet?
Reply #71 on:
August 04, 2009, 04:00:17 PM »
No time for development. I've found a K24A8 for Cham to test on, but scheduling is always an issue.
msedacca
Reply #72 on:
August 07, 2009, 02:07:35 PM »
Just to add my two cents into the pot.
I've had kpro on my turbo accord for 2 1/2 years now, zero problems. I figured out the VTC problem before cham realized it, and it was a very easy fix, just resplicing a wire. I had access to a bunch of stock wiring diagrams, but they're on my other computer that's in storage.
If there ever came a time that Cham didn't want to make any of these anymore, his harness can be easily reproduced if someone knows how to pin wires (which I have no clue on). Steven(JBLAccord from awhile back) and I had gone through the idea of making them, and as you know Cham is basically unreachable (he still has my 6spd I paid him for 6 months ago sitting somewhere).
Kpro is better than anything else available. My car was tuned with smaller turbo, less psi, and generally an inferior setup to another Accord running the RTC kit on the same day at the same time on the same dyno and mine made 15whp more. That's all the proof that you can ever need that it's a better EMS.
I guess the big issue would be the DBW and getting around it. I don't know if its possible to isolate it because it acts like the TPS if I'm not mistaken. That's more of a question for skip/tim/paul/cham, because the TPS is a pretty important part of the power equation, unless maybe you could trick the stock ECU/Kpro into thinking it was a TPS. What about maybe even using a TSX ECU instead of a PRB/PRC ECU? Just some thoughts.
turbHO
Reply #73 on:
August 07, 2009, 06:39:52 PM »
interesting. Hey could you post up the pinout chart? I want to see how difficult it is. I have some experience in electronics class. soo lets see if I learned anything lol
And it is a wideband for the o2. I checked out my friend o2 and when to honda to pick it up.
neoryan7
Reply #74 on:
August 12, 2009, 08:18:13 PM »
I wonder if we can get an kpro hooked up to the odb2 port or have another one just for the kpro. I was reading the hondata install manual for the tsx and it said it was possible. So that way we dont have to take out the ecu when it comes time for smog. This idea is appealing to me because i live in Cali and dont want to unplug/uninstall it everytime.
http://www.carplugs.com/Product_list_Connectors_1.html
That way cars equipped with kpros will be one step closer to being oem in performance.
