September 20, 2026, 11:00:59 AM
Pages: « First < Previous 1 ... 10 11 [12]   Go Down
Author Topic: **Good Tire Thread**  (Read 104217 times)
HEcreated487 pfffft.
« Reply #165 on: November 18, 2011, 08:02:10 PM »
^^ Good to know Thien.  Defininitely looking into those tires as replacements.
Reputation Power: 18
alpha pfffft.
« Reply #166 on: December 05, 2011, 07:14:18 PM »
Getting quotes for some RE-11's..  I think I might pull the trigger.. some pretty good deals..
« Reply #167 on: January 20, 2012, 02:09:12 PM »
So how bad is it really going to be for my car if I only replace one tire, as opposed to both?  I really can't afford to spend the money on a second tire..
quickkick127
quickkick127 pfffft.
« Reply #168 on: January 20, 2012, 03:16:53 PM »
I don't know the exact answer to that but I would think that it would depend how worn the other tire is.  If you run a brand new tire with one that is bald, the effects would be greater than if the new tire was paired up with a tire that still reads a six or seven.  So maybe someone more qualified can help you, what kind of shape is your other tire in?
« Reply #169 on: January 20, 2012, 03:35:45 PM »
the other tire is by no means bald.  there seems to be plenty of tread left on it to last for at the very least another year.
As long as it's not going to cause any kind of damage to the drive-ability of the car, I could care less really.  I hate my car (i have a civic not an accord anymore) and just want the thing to blow up or get totalled somehow so I can get rid of it.
« Reply #170 on: January 20, 2012, 08:26:45 PM »
It won't cause any damage unless its has a big varience in tread depth. Like for instant a brand new tire with 10/32nd of tread on the left front and 5/32nd on the right front may cause transmission slippage or wheel speed sensor fault. But if it only has a varience of only 3/32nd, it should be fine but you will have a tire pull to whatever side has the least amount of tread. Thats only if you are putting them on the front. If you they are going on the rear, it won't cause any damange at all.
« Reply #171 on: January 20, 2012, 08:29:29 PM »
Then don't worry about the tire Brian.
« Reply #172 on: January 20, 2012, 09:04:07 PM »
Oh okay. Thanks thien. Its for my rear tires, so it should be fine. I get paid next week, maybe I'll be able to grab a matching tire then.. we'll see I guess.
« Reply #173 on: January 20, 2012, 09:11:46 PM »
I have the same problem with my new car. When we bought the car, it was out of alignment real bad. The front left wheel had wayyy too much toe out, so that tire is at about 4/32" vs. 8/32" on the other three tires. Obviously now that I've got it aligned (lifetime alignment ftw!) the car wants to pull to the right.
I'm just wondering how much tread will be left on the three good tires when the one tire goes bald...
status
GOMD
status pfffft.
« Reply #174 on: March 01, 2012, 04:27:00 PM »
Went to Costco to get new bridgestone potenza re960as pole positions, 4 of them installed for 480and go to check in dude tells me to wait til march 8th for the tires because they'll be 355 installed. ftmfw!
-Alec
« Reply #175 on: March 01, 2012, 06:27:30 PM »
I had those tires.  They were pretty good all season tires.
status
GOMD
status pfffft.
« Reply #176 on: March 01, 2012, 06:31:00 PM »
good to hear, and thien likes um too. have to be better than the dorals that came on the car when i got it.
-Alec
« Reply #177 on: March 03, 2012, 07:12:00 PM »
The reason why you are getting for that much is because they are discontinued. They no longer make the 960AS Pole Position except in a Run Flat Size which is mainly the 205/55 R16, 225/40 R18, 255/35 R18. Its really for BMW. The 970AS Pole Position replaced the 960AS. Just hope you are getting the Japan made 960AS instead of the Mexico or USA made ones.
« Reply #178 on: April 19, 2013, 07:04:12 PM »
What's a good cheap tire nowadays that's quiet and gets good gas mileage? Not worried about a high performance tire anymore. Tires Plus recommended me some Firestone Affinity Touring tires, but the average review on Tirerack is a 5.3/10. They also have Bridgestone Ecopias, and they got 7.6/10. Everything else is goddamn expensive and is like $650+ after installation.
Pages: « First < Previous 1 ... 10 11 [12]   Go Up
