October 25, 2026, 08:13:36 AM
Pages: « First < Previous 1 2 3 [4]   Go Down
Author Topic: Oil Catch Can DIY [OBX-RCT003]  (Read 39264 times)
« Reply #45 on: October 23, 2009, 10:50:27 PM »
Are you able to stuff anything inside the cans, or are they pretty much closed off? I'm really tempted to get one of these catch cans after seeing the shit in my injector base. The runners were like black. After I get a catch can installed, I think I'm going to do a cleanup of my car. Clean the blow-by in the TB and IM, clean the MAF, etc.
« Reply #46 on: October 23, 2009, 11:01:21 PM »
You can't "stuff" anything in them.  If you can justify spending the money, go ahead and get one.
« Reply #47 on: October 23, 2009, 11:05:21 PM »
Alright, thanks Tim. I was thinking of using the stainless steel scrub things to put in the can, but it's no big deal. Better than nothing. I can't wait to do this. :P
Autodesigner3
« Reply #48 on: February 15, 2010, 02:01:56 AM »
so both of these setups are correct(the first one and http://img24.imageshack.us/img24/9636/dscn2087n.jpg)? which one should i do cause i just got this same catch can and was going to install it for the intake side?
« Reply #49 on: February 15, 2010, 08:21:09 AM »
I believe the one that goes into the intake manifold is "more correct" because the majority of the blow-by goes through there. In other words, you're going to catch more oil on that setup rather than the other one on the intake side.
Autodesigner3
« Reply #50 on: February 15, 2010, 10:14:17 AM »
alright that's what I figured..thanks....wish it wasn't snowing so i could install this
NWINNIE34 pfffft.
« Reply #51 on: June 07, 2010, 10:45:13 AM »
Had a nice long weekend with the K24
Installed Hondata Heatshield Gasket , P2R intake manifold gasket, painted my intake manifold, and installed my OBX oil catch can.....  (intake manifold position)
Installation is a breeze, mounting the catch can is a little tricky, i protected my one hose and attached it to that.... the can sorta sits perfect in that little area near the radiator.... doesnt move at all
tubing was a breeze, just a few hose clamps (which i plan to clean up) and it worked out great
10-15 miles on it so far and my bottom tube is already brown (showing signs of oil vapors being caught)
as you can see behind my injector plate area was pretty oily and dirty, runners were oily, injector runners were oily.... so hopefully the catch can will cut down on this issue
Before:
Intake Mani - Off
Paint intake Mani -
Take off injector plate and gasket - OILY !!!
Bought 3' of Tubing from home depot and hooked up my OBX Oil catch can - i used steel wool as the filter
And TODAAAAAA !!! my hard work pays off... i like the black IM look
Pages: « First < Previous 1 2 3 [4]   Go Up
