September 27, 2026, 10:20:57 AM
Pages: « First < Previous 1 ... 9 10 [11] 12 13 ... 31 Next > Last »   Go Down
Author Topic: The Only Fog Light Thread You Should Ever Post In  (Read 265295 times)
« Reply #150 on: November 26, 2009, 01:31:01 PM »
Check your in dash wiring harness ground.
CYANiDE pfffft.
« Reply #151 on: January 12, 2010, 01:35:44 AM »
DriveAccord isn't working for me. I want to be able to have them always on (basically if switch is on it will always turn them on if its off it'll keep them off). I bought the housing so far and am awaiting OEM wiring stuff before I take this on. Should I wire them according to the original instructions then when I get it to work that way modify the wiring harness?
« Reply #152 on: January 12, 2010, 06:52:48 AM »
That'd be the best way to do it. There's two mods you can choose from. Modify the harness at the switch, or under the hood. I'm not sure what the colors are for the 7.5 gen but mine were modified at the switch.
Icebox pfffft.
« Reply #153 on: January 12, 2010, 07:01:27 AM »
Quote from: "Icebox"
ok, here is the thread with the info on how to get them working. i installed a switch between the two wires that you are supposed to splice together so i could turn off the fogs when my hibeams are in use.
http://www.driveaccord.net/forums/showthread.php?t=6873
« Reply #154 on: January 12, 2010, 08:20:29 AM »
So, you want your fogs to turn on with a switch, regardless of whether your parking lights or headlights are on?
CYANiDE pfffft.
« Reply #155 on: January 12, 2010, 10:43:16 AM »
Basically yes. DriveAccord is up, but I wanted to know if my process would be similar since that is for using them with the parking lights. I'm going to end up wiring them as per the instructions on the Honda PDF then once I confirm they are working would tackle the job to have them light up independently.
Icebox pfffft.
« Reply #156 on: January 12, 2010, 02:30:54 PM »
im interested to see how this would work. a diy is must when you figure it out. take photos of the process please.
« Reply #157 on: January 12, 2010, 02:49:26 PM »
I'd have to double check the diagram, but you'd basically just wire up the power input to a 12 volt source that is on when your car is running.  Not a big deal to make happen.
mnkyman
mnkyman pfffft.
« Reply #158 on: January 14, 2010, 01:18:59 AM »
Anyone have experience with this particular eBay Seller and/or the exact fogs pictured?
http://cgi.ebay.com/ebaymotors/Fog-Ligh ... ccessories
http://cgi.ebay.com/ebaymotors/Fog-Ligh ... 2c52679aee
Yes I know that there will need to be some modification done to fit it to the bumper, but anyone done this? Any insight on this? Also, the auctions above don't come with any harness...does anyone know if the USDM harness will fit the above fogs?
(if this is in the wrong forum, please move...i wasn't sure if this would be electronic or just general, since i'm asking more about the particular eBay seller)
Sam -|- 2006 I4 Sedan SE
k24low20z pfffft.
« Reply #159 on: January 14, 2010, 01:41:18 AM »
just some light modification done to fit it to the bumper, but is pretty easy to do. you can use any after market  or USDM harness  with h11 bulbs..
« Reply #160 on: January 14, 2010, 08:03:09 AM »
Moved to the appropriate forum. As for the questions, Lex has it done. Like he said, all you would need is minor mods and the USDM harness plugs right up. The only difference between the ASEAN fogs and the US fogs is the actual light housing.
CYANiDE pfffft.
« Reply #161 on: January 14, 2010, 09:27:01 AM »
OEM harness and switch will run you a little bit under $100 + shipping from Bernardi Honda which isn't bad at all. $15 is really cheap even for replicas. I picked up some OEM housings (I guess JDM then LOL) and waiting on my other stuff to get here. I have the PDF for the install on an '06. Shoot me a PM if you want it.
« Reply #162 on: January 14, 2010, 09:38:23 AM »
Also, this has been discussed before. Here: viewtopic.php?f=38&t=2156.
As for the ebay seller, no experience with him.
« Reply #163 on: January 14, 2010, 01:19:39 PM »
I'd use the OEM USDM harness.  Bernardi Honda and Majestic Honda are in my area, so I can pick up and ship the harness if you want.  I'd contact lemonjelly about the actual installation.  He did an 06-07 front end conversion and has the Depo aftermarket/replica Inspire fog lights.
« Reply #164 on: January 14, 2010, 01:33:47 PM »
That's right! I completely forgot that Steve did the same conversion.
Pages: « First < Previous 1 ... 9 10 [11] 12 13 ... 31 Next > Last »   Go Up
