September 28, 2026, 11:16:59 AM
11
12
31
Topic: The Only Fog Light Thread You Should Ever Post In (Read 265442 times)
Re: Foglights on without headlights on 7.5 gen
Reply #135 on:
October 22, 2009, 10:00:59 PM »
How much time do you have? Maybe you should hit me up on AIM so I can explain.
Reply #136 on:
October 23, 2009, 01:35:53 AM »
I say, find the blue wire in your engine harness for the fog lights, and ground that. Ignore that thread on DA. I don't trust it.
I actually followed the steps in the thread on DA.. It works, and I haven't had any issues with it..
Reply #137 on:
October 23, 2009, 07:39:11 AM »
What happens when you dim your gauge cluster?
Reply #138 on:
October 23, 2009, 08:31:59 AM »
ive had mine wired like that for almost two years with no problems, like i said before, i installed a switch between the two wires so i could manually revert back to the stock wiring.
Reply #139 on:
October 23, 2009, 05:57:51 PM »
Quote from: "Icebox"
That sounds like a pretty good idea too. I think the safe bet, is to just cut that wire and ground both ends of it. My concern is that it's connected to a variable resistor. Nobody has answered my question yet.
That will be the true test of how well this mod works.
najeezy
inspire fogs with OEM harness
Reply #140 on:
November 15, 2009, 05:40:34 PM »
i was reading an old post about using an OEM harness for inspire fogs. I was reading the old thread and there was a post saying to buy parts 5,6,7,8,9 from this list:
http://www.hondaautomotiveparts.com/aut ... GLIGHT+KIT
and went i went to majestic honda and searched up foglight parts for the 06 accord sedan (which is the accord model i have), the parts were different. i was thinking the parts would be numbers 5,6,7,8 on this list:
http://www.hondaautomotiveparts.com/aut ... +%28+06%29
NOTE: the links are 2 different model years, im pretty sure the first link is for 03-05 accords, and the second is 06-07. I'm probably going to buy the stuff from the 2nd link, but I just want to make sure with the experts here. would I need the parts from the first list or the second list. Sorry if this is confusing, if you ask a question, I'll try to clarify what I'm asking. Thanks for the help guys
Re: inspire fogs with OEM harness
Reply #141 on:
November 15, 2009, 05:48:54 PM »
That depends on what year your car is. If you have an 03-05, then you get the parts from the first list. If you have an 06-07, then you get the parts from the second list. There isn't a huge difference between the two versions, except how fog lights are controlled in the engine bay. Either way, get whatever is meant for the model year of your car.
najeezy
Reply #142 on:
November 15, 2009, 10:02:02 PM »
alrighty. im a 06. just wanted to make sure haha. thx tim
Reply #143 on:
November 23, 2009, 02:15:13 PM »
I found inspire replicas for $60 shipped, but they only come with the housing
So as mentioned would I only need 5,6,7,8 too and bulbs to work those fogs (plus the obvious hardware to mount the fogs)
Reply #144 on:
November 23, 2009, 02:48:08 PM »
I'm assuming you'd need everything minus the OEM housings. Switch, both harnesses, and bulbs.
Reply #145 on:
November 23, 2009, 03:00:25 PM »
correct
Reply #146 on:
November 23, 2009, 03:39:08 PM »
might just pick up the fogs, and install them next year
Reply #147 on:
November 26, 2009, 12:50:50 PM »
So almost all is well when I wired it up. It's just that the green indicator light on the button doesn't work anymore, not sure why, but I can live with it.
Reply #148 on:
November 26, 2009, 01:12:29 PM »
The green indicator light that shows your fog lights are on or the backlight for the "fog light" icon?
Reply #149 on:
November 26, 2009, 01:22:31 PM »
The one that shows that they are on.
11
12
31
