July 26, 2026, 12:05:27 PM
Bolt Ons
pulley kits?
Topic: pulley kits? (Read 62712 times)
Re: pulley kits?
Reply #30 on:
June 27, 2009, 01:54:27 PM »
The type a belt has a different part number than the TSX belt and I do not recommend using it.
03 CM55 NBP
MT
Re: pulley kits?
Reply #31 on:
June 27, 2009, 08:33:34 PM »
what is the difference with say using a type s or tsx belt?
Re: pulley kits?
Reply #32 on:
June 28, 2009, 12:57:20 PM »
Well, here's the raw data:
Unorthodox racing makes pulley kits for the TSX and Accord, and they are magically the same part number.
The TSX and Accord accessory belt both have the same part number.
The RSX-S kit on UR's website has a different part number than the TSX/Accord kit.
The RSX-S belt has a different number than the TSX/Accord belt.
This information leads me to believe that the RSX-S belt is a different length than the TSX/Accord belt. This would account for the different part numbers on UR's website, because the pulley kits have different dimensions. UR would not have designed two different kits if there wasn't a reason to, therefore I believe that there are significant differences to the designs that prohibit using the type-s belt on our vehicles. There's nothing special about a Type-S belt....they're made by the same company, in the same factories, by the same workers as the TSX/Accord belts are. The only difference is in the size. If you run a belt that is too tight (too small), it will wear faster and generate more wear on your tensioner assembly. If you run a belt too loose (too big), the belt will slip and you will lose efficiency in all systems that utilize that belt, which includes an extra added whammy for us because our water pump, AC compressor, Power steering system, and Alternator run off of one belt. You lose the belt and: your AC stops working, you lose Power steering, your battery dies, and your car overheats.
03 CM55 NBP
MT
Re: pulley kits?
Reply #33 on:
July 02, 2009, 10:40:23 PM »
got ya.so stick with a accord/tsx belt.
Re: pulley kits?
Reply #34 on:
July 10, 2009, 03:44:56 PM »
Quick question: Where can I buy the crank pulley tool for my car? Would I have to buy one online, or would a local store like Autozone have it?
Re: pulley kits?
Reply #35 on:
July 10, 2009, 04:06:21 PM »
Auto Zone has pulley pullers you can use.
Re: pulley kits?
Reply #36 on:
July 10, 2009, 04:58:21 PM »
I've got pulley pullers, but I was talking about this:
But lo and behold, Google was on my side today. I found this:
http://www.hondatuningmagazine.com/tech ... index.html
HONDA PART #: 07MAB-PY3010A
Hopefully this will do the job.
Re: pulley kits?
Reply #37 on:
July 11, 2009, 12:58:53 AM »
get PB blaster ready and the tool i think someone was selling it on the F/s section might have been a while but he still might have it. Or else its like 40 bucks from napa auto. youtube honda crank pulley you should have an idea
Re: pulley kits?
Reply #38 on:
July 11, 2009, 06:36:59 PM »
I think it was Cole (Heckler) selling that thing awhile back. He's been inactive for a minute though.
Re: pulley kits?
Reply #39 on:
July 12, 2009, 02:57:08 PM »
Hey guys, I found a pretty good deal at Amazon for the crank pulley remover tool:
http://www.amazon.com/Powerbuilt-648796 ... 905&sr=8-3
However, I plan on renting one from my local Advance Auto Parts store. They want $99.99 to rent it, but I get a full refund back when I turn it in. So I'm just going to get my stepdad's plastic and do it that way. But for the rest of you people, I'd definitely take the Amazon deal into consideration. That's a steal for being a $60+ tool.
Silver Bullet
Re: pulley kits?
Reply #40 on:
September 23, 2009, 12:12:11 AM »
Hey guys I just got my pulleys installed today. I wanna make sure it was installed right so I have a question. Can anyone tell me what the centerbore is? It said the "center bore" had to be coated with anti-seize. What I'm asking is that, is the center bore the hole itself INSIDE the pulley or the area around the hole on the outside? Thanks!
2006 AV6 6MT
Silver Bullet
Re: pulley kits?
Reply #41 on:
September 23, 2009, 01:08:10 AM »
nvm i searched and found the info, i'll have to go back tomorrow
2006 AV6 6MT
CurrentStatus
Re: pulley kits?
Reply #42 on:
August 25, 2010, 09:03:27 PM »
So hey, simple question since you commented about your UR pulley set....how much ( guestimated) power did you think you gained? I have been eyeing them for about six months........
To Each His Own
Re: pulley kits?
Reply #43 on:
August 25, 2010, 09:12:41 PM »
I wouldn't expect a huge power gain. They basically lessen the rotating mass making the engine more efficient. I'd expect less than 5HP.
pbplayer257
Re: pulley kits?
Reply #44 on:
September 16, 2010, 12:36:41 AM »
Does anyone recommend getting UR pulleys? Im on the fence about them, and i need some advice with someone who has first hand experience??
