July 26, 2026, 12:03:53 PM
Bolt Ons
pulley kits?
Topic: pulley kits? (Read 62711 times)
pulley kits?
April 15, 2009, 07:52:58 PM »
i was looking at pulley kits, and i know more or less how they work, but i thought i better ask from experience before making a decision... I have noticed that few members just have the crank pulley, not the pulley kit (ps, alt, crank) does the kit drastically slow down the accessories (a/c, heater, altenator) what are some recommendations?
Re: pulley kits?
April 15, 2009, 08:08:27 PM »
Do your homework! There are different type's some are stock diameter, and just lighter than stock(shouldn't affect accessories) Others are under drive which differ from stock, and could affect accessories.
Re: pulley kits?
April 15, 2009, 08:52:24 PM »
the stock ones are usually for superchargers... i want to know how much does the pulley kit affect a/c, heater, cuz i live in Canada so i need the heater during those harsh winters! so is that the reson why people get just the crank underdrive pulley as opposed to the whole kit?
Re: pulley kits?
April 15, 2009, 11:22:11 PM »
I have Unorthodox Racing under drive pulleys. They've been on my car for almost 2 years. I called Unorthodox Racing for information about these before I purchased them and installed them. They only under drive your components by 10%. I have not experienced any loss in power from my alternator, no issues with my power steering, and my a/c works fine (after I replaced a bad compressor).
Re: pulley kits?
April 16, 2009, 10:38:39 AM »
Ditto. Mine have been on for the last year or so.
Rustywaffle
Re: pulley kits?
April 16, 2009, 12:15:10 PM »
+2 i love my UR pulleys, never had a problem at all with em
Re: pulley kits?
April 16, 2009, 08:23:51 PM »
so if i was running a crazy system than i might want to get the ralco stock size kit. do the crank pulleys have any long term affects on the crank??? i noticed there is no dampener on the after markets crank pulleys
Re: pulley kits?
April 16, 2009, 10:54:27 PM »
There is an article on the longevity myths and it might actually be in this subforum...read up.
Also, just to make sure you know, the V6 people are the only people here just running crank pulleys, that's because it's the only pulley available for replacement. Most if not all kits for K series motors are underdrive.
03 CM55 NBP
MT
Re: pulley kits?
April 17, 2009, 12:17:31 AM »
On the topic of having a system, I was running a 2800 watt system with the stock alternator with under drive pulleys and didn't suffer any ill effects at all.
Re: pulley kits?
April 17, 2009, 02:11:28 AM »
yes there is an article. I posted it. I got it from Acurazine
viewtopic.php?f=10&t=464
Happy reading
msedacca
Re: pulley kits?
April 20, 2009, 11:54:52 AM »
i've got a 1000watt system, Kpro, sat radio, and a turbo, and have had 0 ill effects from the underdriven pulleys. Had them on for 3 years now (was one of the first
) Your headlights dim slightly when the A/C kicks in at idle (only to the eyes of someone paying attention for that kind of thing) or you use your windows. You should be fine even with the craziest system, I know Tim has one of the sickest out there.
turbHO
Re: pulley kits?
April 20, 2009, 12:26:28 PM »
The headlights will typically dim when the AC clutch kicks on even if you don't have a pulley kit...they don't dim if you have HID's though
03 CM55 NBP
MT
Re: pulley kits?
April 20, 2009, 01:18:38 PM »
damn tim 2800watts? that must sound pretty good, but i will probably only run a 1000watt when and if i ever get one.... i have pretty much made up my mind, and have decided to go with the UR pulley kit. thanx for clearing up all my doubts. i knew i could count on elitecm to help me make my decision....
Re: pulley kits?
April 20, 2009, 04:05:53 PM »
was
running a 2800 watt system. My current set up is 1100 watts with all the speakers on when playing 5.1 audio. During normal use, it's about 1000 watts. It will bump up to about 1300 watts when I get a 2nd sub.
Silver Bullet
Re: pulley kits?
June 24, 2009, 07:06:37 PM »
I just ordered my UR underdrive pulleys. It's the one for the tsx/accord. Does anyone know which belt I'd have to purchase for the pulleys?
2006 AV6 6MT
