April 25, 2026, 07:44:36 PM
My K Series Is Losing Oil Thread
Topic: My K Series Is Losing Oil Thread (Read 49050 times)
Re: Oil Burning
April 15, 2009, 03:40:42 PM »
This is what mine looked like when I pulled them out at around 84,991 miles on them.
Re: Oil Burning
April 15, 2009, 04:19:37 PM »
You guys see those grey little blobs, that is burnt oil deposites, you both have oil gettting past the rings into the combustion chamber.
Slammed, cylinder 1 looks especially crappy....
Slammedk24
Re: Oil Burning
April 15, 2009, 04:23:54 PM »
So what do you recommend doing to help this problem from getting worse. Besides changing the type and weight of oil I run but is there anyhting else I should do
Tory
"Low and Slow"
Re: Oil Burning
April 15, 2009, 05:31:17 PM »
Nothing that can be done, clean them off, change oil weight and look again after a while, if is persists then it would take new pistons and rings to fix it, but if that is 26K miles it isn't too bad, but the engine is getting tired.....
Slammedk24
Re: Oil Burning
April 15, 2009, 05:57:59 PM »
Ok how should I clean the plugs with a fine wire brush or is that too harsh. And do you recommend that I change #1
Tory
"Low and Slow"
Re: Oil Burning
April 15, 2009, 06:44:34 PM »
Use eaither a stainless or brass brush and then check the gap before reinstalling.
Re: Oil Burning
April 18, 2009, 12:05:03 PM »
Most honda dealerships have a few old school technicians with spark plug cleaners...they use a media blasting bag that takes all the gunk off.
Just so you guys know, synthetic does burn faster and more readily than conventional oil, and K series are indeed oil eaters. I noticed it in my car along with a bunch of other people. It may be due to the fact that our VTEC operates constantly...that's all I can think of to accelerate oil deterioration and consumption.
Paul...6-9 PSI at idle?
wow! K series idle oil pressure is in the mid 40's at idle and near 100 PSI under load!
03 CM55 NBP
MT
Sworkhard
Re: Oil Burning
April 19, 2009, 02:27:03 AM »
I've noticed my car has suddenly (in the last 7000 or so miles) started burning oil. so about 1000 miles ago i replaced the pcv valve and did a seafoam treatment. Now i'm monitoring the situation (still too soon to tell). The increase in oil consumption seems to coinside with installing my injen short ram intake, so if oil consumption is still high, i'll try putting my oem intake back on and see if that helps. I was burning about 1/2 quart every 5000 miles, but my last change i burned over 2 quarts in the same amount of time
I have a bit less than 130000 miles on my car. When i did my last change, the oil seemed dirtier and grittier than I remember from previous changes, dispite a 4500 mile oci. vs my usually 6000 mile oci
[size=150]Stephen[/size]
03 Accord EX-L 5MT
Re: Oil Burning
Reply #23 on:
April 19, 2009, 05:55:26 AM »
Skippy- those reading are at full operationg temprature, when cold yeah I get 50-70PSI at idle, hell the factory manual only calls for min 10PSI at idle.
Sworkhand- One thing with seafoam, where do you think all that carbon goes when you use the stuff?
Re: Oil Burning
Reply #24 on:
April 19, 2009, 11:21:39 AM »
Paul, sorry to keep this going, but I'm still amazed! K series oil pressure is in the mid 30's to 40's at idle at operating temp. I can't believe J series have such low oil pressure at idle! So interesting!
03 CM55 NBP
MT
Sworkhard
Re: Oil Burning
Reply #25 on:
April 20, 2009, 07:57:56 PM »
NVA-AV6: I checked the oil before I did the seafoam. I did do a lot more cold starts and very short trips on this oil change than usual though so that'll have a lot to do with oil consumption as well. I also did a auto-rx treatment 3 oil changes ago so that might have something to do with the grittier oil as well. (The stuff works really well, but very slowly). I'll be following it as i'll be doing almost all highway driving this summer so it should go back to the regular 1/2 quart per 5000
03 Accord EX-L 5MT
Serious oil consumption
Reply #26 on:
June 11, 2010, 11:19:04 PM »
I have noticed that my car started guzzling oil recently. In a little under 4,000 miles, I have had to add 4 quarts of oil. In the past, I would have to add about 1.5 to 2 quarts between oil changes (5k miles for me).
From Tim's and Skippy's advice I took off the valve cover and took some pictures of the cams. The two exhaust cams that were facing me look very rough with some slight indentations. The intake cams look a lot better but I'm no expert.
Any of you engine gurus, please share your thoughts about what can be done, if anything. I'm not really in the position to do an engine swap, I'd like to save what's left of this motor. What are my options? Thank you in advance!
Cylinder 1 exhaust cam
Cylinder 3 exhaust cam
Cylinder 1 intake cams
Spark plugs
Inside of my valve cover
Re: Serious oil consumption
Reply #27 on:
June 11, 2010, 11:51:56 PM »
What oil do you use? How many miles do you have?
If you're not losing the oil, then my first guess would be an oil pressure issue.
Reply #28 on:
June 12, 2010, 01:11:39 AM »
Mileage is 131,xxx. 10w-30 Valvoline Max Life
Reply #29 on:
June 12, 2010, 05:21:10 AM »
Exhaust cam is toast and the oil is going somewhere, I would have to imagine it is being burnt, now the question is are the valve steam seals gone or are the rings, get a compression test.
