September 21, 2026, 11:58:50 AM
Brakes
Rear brake contact
Topic: Rear brake contact (Read 57059 times)
Re: Rear brake contact
Reply #30 on:
November 21, 2011, 12:23:59 PM »
Quote from: Rushzer0 on November 21, 2011, 11:40:53 AM
Oh ok good aha! I know some people make their living off sales. I just didn't want to take food off anyones table, so to speak. Brand is DNS they are rebuilt semi loaded calipers. The grand total is a staggering $866.62 taxes in. But $260 of that is core charges, so $606.62 with your cores (if you can find some ruined legend calipers from a junkyard to give us for cores or something) or if you can't locate legend cores it's $716.62 :/ kinda pricey I'm sure I can get a better price if I talk to the manager (the person I went to for the quote is a tight ass and didn't apply any sort of discount :p), and maybe work something out with shipping.
Holy shit parts are expensive in Canada... I'd take Accords back as cores on legends.
Reply #31 on:
November 21, 2011, 01:19:05 PM »
Ya it's pricey for stuff here :p like I said though I can talk to the manager maybe knock a good chunk off that. The counter person wouldn't use my discount, but the manager might allow it. My price was around $560 taxes in
Reply #32 on:
November 21, 2011, 08:57:18 PM »
Thanks for the price. Definitely high but sadly we get rocked in Canada.
I'll drive down to Buffalo for a deal
@Mike, which brand were you quoting prices on?
Again... everyone has been a great help
Reply #33 on:
November 22, 2011, 11:08:00 AM »
I think Fenco reman's are the only ones I could get my hands on.
Reply #34 on:
December 20, 2011, 08:53:02 PM »
make sure you align the cross on piston the right way. if you didnt before there is a chance why it wasnt working correctly
Reply #35 on:
December 20, 2011, 10:12:36 PM »
^Good point. You need to make sure the little dimple in the pad is in that "slot" in the piston.
Reply #36 on:
March 07, 2012, 08:24:40 PM »
Long update.... Mechanic checked out the rears today
Rear caliper he said probably needs replacing, pads and rotors have to go as well
Front pads and rotors are good...
Do I need to replace pads or rotors on all four corners?
Reply #37 on:
March 07, 2012, 08:55:03 PM »
If the front rotors and pads are good, then there's no need to replace them.
Reply #38 on:
July 19, 2012, 06:59:29 PM »
I'm also in the same boat here. I replaced my front and rear brakes summer 2010, the fronts are wearing fine, the rears have concentric rust rings on the rotors. About 2 months ago I took the rear calipers off, and the slide pins were stuck. I cleaned them off, lubed them up, and re installed. After driving a couple of days, I checked the rear rotors, and the rust rings were getting worn off. I thought I had fixed the problem. Now 2 months later, the problem has returned. Maybe I just need to really lube them up again. Is it worth replacing the slide pins or anything?
Reply #39 on:
July 19, 2012, 09:57:08 PM »
You can get the pins pretty cheap. The design of the calipers is poor to say the least.
Reply #40 on:
July 19, 2012, 11:37:56 PM »
You may also want to check the rubber boot that covers the slide pin. If it isnt fully sealed off, water and other dirt/debris can seap inside causing the pins to seize up.
Reply #41 on:
July 21, 2012, 12:19:39 PM »
I replaced all my rear sliding pin and boot. Those pin also wear out over time.
Reply #42 on:
July 22, 2012, 12:43:11 AM »
i has same issue on my driver side one , what has worked for me was changing the brake lines to stainless steels ones . after going through 3 pairs of calipers i notice that my rear line had too much play when they get hot ,getting spongy and causing the caliper not to work properly
Reply #43 on:
August 07, 2012, 11:27:21 PM »
Anyways update... I bought locally rebuilt OEM calipers
Got them installed with new rear pads and rotors
Now my brake pedal is soft. Braking is good and a lot better if I stomp, but I have to press more than I used to
Shop was saying either the new calipers had a problem or the master cylinder is toast... thoughts? They were leaning to the master cylinder
Reply #44 on:
August 07, 2012, 11:34:48 PM »
Sounds odd if the issue wasn't there before I would lean toward what they just changed. That or some air in the lines.
