September 29, 2026, 03:17:03 PM
Audio Systems
Power wire
Topic: Power wire (Read 30480 times)
CNY240
Power wire
February 06, 2011, 09:08:22 AM »
Looking for tips and tricks and pictures of how to run and where to run your amp power line from battery to trunk for a amp. mostly where is it the easiest to run through and what gromets or where to drill and add your own. pictures and how to pop off plastic or remove plastics tips are all great helps for this!
Re: Power wire
February 06, 2011, 11:37:41 AM »
I'll let you know right now that you can run power wire from your battery to your trunk without drilling any holes. I can get pictures in a few weeks, but it's too damn cold outside and I'm too damn busy packing up my shit to move.
Re: Power wire
February 06, 2011, 11:42:42 AM »
A quick search revealed
this thread.
Search is your friend. Try it sometime.
CNY240
Re: Power wire
February 07, 2011, 08:01:59 PM »
@ Cracker Teg- yes it is helpful but i didnt find it too be. I did search it before posting : P im trying to eliminate the uneeded material and focuz on running through the fire wall and inside the cabin for poping the plastics of to hide a 4 gauge wire. it was helpful but when i went to find where they ran it, i couldnt. thats why im trying to find some more pictures detailing only the power wire how fellow members have done it
CNY240
Re: Power wire
February 07, 2011, 08:03:02 PM »
@ Timot- i know its too cold! i tried looking for that gromet and couldnt find it since i dont know where 100% thanks alot!!
Re: Power wire
February 07, 2011, 08:35:37 PM »
It will be a few weeks, but I'll have pictures when I have time.
Re: Power wire
February 07, 2011, 10:31:35 PM »
The grommet in the fire wall is right about where your clutch pedal would be (to the left of the brake pedal about 3-4 inches up), very noticeable. I ran it from the grommet right behind the panel where the interior fuse box is and under the panels of the door steps straight under the rear seat from the back floor panel.
CNY240
Re: Power wire
February 07, 2011, 10:45:05 PM »
idk if it makes a differnce im in a 05 accord 4 dr. but ill check tomorrow. thanks man!
Re: Power wire
February 07, 2011, 11:15:33 PM »
Quote from: CNY240 on February 07, 2011, 10:45:05 PM
idk if it makes a difference im in a 05 accord 4 dr. but ill check tomorrow. thanks man!
No it doesn't, just make sure you run the wire on the driver side since the battery is located on that side! Run your RCA cables and remote wire on the passenger side to reduce interference. I'm NO expert
but my system sounds good and the setup is nice and neat!
...good luck!
Re: Power wire
February 07, 2011, 11:51:55 PM »
Run your remote turn on wire down the same side as your power wire. Keep all power wires away from your RCA's if you want to prevent induced noise. I'm no expert either, but I am a licensed MECP installer and have an extensive background in electronics, audio systems, and acoustics.
Re: Power wire
February 08, 2011, 10:00:16 AM »
Quote from: timot_one on February 07, 2011, 11:51:55 PM
Sounds "experty" to me.
Re: Power wire
February 08, 2011, 10:37:27 AM »
CNY, just like Billy said, its that plastic grommit to the left of the brake pedal. If you have a manual, you can't use that hole. As for the year and model, it doesn't matter. The firewall is the same for all 7th gen Accords. BTW, I'm Z.
CNY240
Re: Power wire
February 09, 2011, 08:46:31 AM »
I do infact have a manual acoord.... fml.... but any quick pictures would help also. as for RCA's im splicing into the rear speakers with one of the line out converters for my RCA's so interferance shouldnt be an issuse just need the aid on the power wire thats my only hold up
Quote from: CrackerTeg on February 08, 2011, 10:37:27 AM
so where should the wire be going Z now that you ahve shot down that idea
Re: Power wire
February 09, 2011, 09:39:25 AM »
i ran mine through a grommet that is located to the right of the gas pedal
Re: Power wire
February 09, 2011, 04:30:30 PM »
Quote from: CNY240 on February 09, 2011, 08:46:31 AM
HMmm...
splicing into the rear speaker wires to coneect and RCA cable doesn't sound like a good idea bro... [smh] I would personally run theat RCA from the amp straight to your H/U. If you are running to a stock H/U I would suggest obtaining a converter.
