September 02, 2026, 08:19:11 PM
540
541
542
543
Topic: What did you do to your Gen7 today? (Read 3689562 times)
Reply #8100 on:
December 31, 2014, 11:09:56 AM »
Yes. That's the whole reason for this push to get it all done. I'm picking up a trailer tomorrow and driving out to PA on Friday. Gonna impose on ginger Ryan and hang out with him that night and then hit the dyno on Saturday to finish tuning. Only a few small things to finish up today before firing it up. I need to get the garage warm first though. It's freezing out.
Reply #8101 on:
December 31, 2014, 01:57:56 PM »
Nice Tim, good luck this weekend.
Thanks Ike
Loaded up a Type - S cal with 410 injectors selected, set fuel pressure, started here up
, went through the gears while it was on the lift to get fluid in all the nooks and cranny of the tranny, brought it up to temp (felt like forever with the bigger capacity radiator), checked for leaks/weird noises/faults, buttoned up interior, needed a new accessory belt because it was making more noise than before the build with the new PS pump (Katie helped with this in the Advance Auto parking lot), Paul took it for a test drive with me and got jelly when he chirped the tires going into 2nd at around 2-2.5k rpm. I was told repeatedly to keep the rpm below 3k unless absolutely necessary.
Last Edit: December 31, 2014, 01:59:58 PM by Rich01
Reply #8102 on:
January 01, 2015, 09:39:58 AM »
Good stuff Rich!
I fired up the motor yesterday too. Everything is back together and it's ready to load up on the trailer to get hauled out to PA tomorrow.
Reply #8103 on:
January 02, 2015, 09:57:41 PM »
Checked tranny fluid levels, oil n filter change and topped off my coolant. Pured the oil through a strainer to verify no metal shavings were present.
Reply #8104 on:
January 03, 2015, 01:07:45 AM »
What break in oil are you using?
I loaded up the Accord on the trailer and towed it out to PA today. Tune is in the morning. Can't wait to see what happens. Hopefully it does better this time around.
Reply #8105 on:
January 03, 2015, 08:02:23 AM »
Nothing special Tim, just conventional Castrol 10w30. Changed within the first 500 miles then around 1500 and then every 3k after.
Re: Re: Re: What did you do to your Gen7 today?
Reply #8106 on:
January 03, 2015, 11:52:20 AM »
Quote from: timot_one on January 03, 2015, 01:07:45 AM
good luck
Reply #8107 on:
January 04, 2015, 02:28:31 AM »
Quote from: Rich01 on January 03, 2015, 08:02:23 AM
I'm surprised Paul didn't recommend break in oil.
Quote from: Mike on January 03, 2015, 11:52:20 AM
good luck
Thanks Mike. Things went pretty good today. I just got back about an hour ago. Car is still on the trailer. I didn't want to wake the neighbors trying to unload it, so I'll pull it off tomorrow morning.
Everything was working fine. Had a small issue with my boost control solenoid, but switched out the 3 port I had over to a 4 port and now I have boost by gear.
Reply #8108 on:
January 04, 2015, 07:50:08 AM »
Quote from: timot_one on January 04, 2015, 02:28:31 AM
Timbo, the amount any type of assembly lube I use mixes with the conventional oil giving it the high molybdenum content of break in oil.
Reply #8109 on:
January 04, 2015, 08:30:02 AM »
I thought break in oils promoted having a high zinc content?
I know there are different opinions of whether to run break in oil or just whatever cheap stuff you can find.
Reply #8110 on:
January 04, 2015, 05:00:31 PM »
Put the Sport into winter mode today. My old 6-6 wheels are lookin pretty rough... but this is prolly the last season for the tires so I don't care I just threw em on. Let me know if anybody wants em in the spring. Lol
Reply #8111 on:
January 04, 2015, 08:02:04 PM »
Replaced the grommet for the hole in the firewall where the wideband is routed through. Also got, my axles replaced under warranty so I have a spare set. Also Dom got me going on a pretty good cal. Brought up my idle rpm a little so the vibration isn't as bad. Now I need to get some miles on her so we can see what it looks like up top.
May have to get traction control. It was wet today and merging on the highway in 3rd about 2800rpm, I could feel it starting to get lose.
Reply #8112 on:
January 04, 2015, 08:56:59 PM »
Pulled it off the trailer and backed it into the garage. Going to tweak a few small things and try to take it out this week some time.
This is the result of yesterday's tune.
Reply #8113 on:
January 04, 2015, 10:51:47 PM »
Dat torque curve doe...
Reply #8114 on:
January 05, 2015, 12:40:57 AM »
Consistent....
540
541
542
543
