November 07, 2026, 01:07:08 AM
Pages: « First < Previous 1 ... 510 511 [512] 513 514 ... 596 Next > Last »   Go Down
Author Topic: What did you do to your Gen7 today?  (Read 3817787 times)
Pascal
Pascal pfffft.
« Reply #7665 on: May 18, 2014, 02:09:43 PM »
Did a seafoam motor treatment today. I'm not very impressed.  Embarrassed I did 1/3 oil, 1/3 gas tank, and 1/3 through a vacuum line. There wasn't almost any smoke appart form the rear of the engine which was my leaking flex-pipe and gasket. Looked more like blue smoke than white smoke to me too.  Maybe it clogged my catalytic converter, or maybe it already was clogged. Getting a new one anyway in less than two weeks.
« Reply #7666 on: May 18, 2014, 03:11:55 PM »
That's one reason why I don't like seafoam. Change your oil on a regular basis and use top tier fuels and you don't need to use that stuff.
Pascal
Pascal pfffft.
« Reply #7667 on: May 18, 2014, 03:54:15 PM »
yeah well for some people it seams like it was working great. hope I didn't just made my engine worse than it was before ...
Reputation Power: 18
alpha pfffft.
« Reply #7668 on: May 18, 2014, 04:44:01 PM »
I agree.. I've heard more horror stories from seafoam treatments than success stories..
« Reply #7669 on: May 18, 2014, 05:18:04 PM »
use the 3m kit. its better.
« Reply #7670 on: May 18, 2014, 11:02:39 PM »
I wouldn't use any of them.  If it knocks anything loose and out your exhaust, it will just end up clogging your cat.  If you change your oil and use top tier fuel, you won't need to use any of that stuff.
BOT though.
I installed the valves and inner valve springs on cylinder 1 on my head and bolted on to the motor so I can check for valve to piston clearance with my new pistons and intake cam.  I also cleaned and painted my Moroso baffled oil pan.
« Reply #7671 on: May 20, 2014, 04:06:24 PM »
Replaced a some fuses, relay, and redid the wiring for my fog lights, stupid eBay crap. The eBay relay was crap I converted it to a regular Bosch style cube relay. Much cheaper and easier to find
« Reply #7672 on: May 20, 2014, 04:17:27 PM »
^my eBay fogs went to crap too. On the search for OEM.
Took some more pics, and hunted for parts per usual.
« Reply #7673 on: May 20, 2014, 05:32:41 PM »
Yeah no kidding. I found out the fuse blew a long ago but the wire still bridge a connection. So they lights were still working until a few days ago. Pulled the fuse it and it was done for. Melted plastic.
Pascal
Pascal pfffft.
« Reply #7674 on: May 20, 2014, 05:45:29 PM »
Same happened to me, replaced the fuse and fuse holder with a waterproof one.
« Reply #7675 on: May 20, 2014, 09:56:49 PM »
Changed front brakes. Anyone with legend calipers have issues with EBC pads? They were correct part but wouldn't fit in the bracket. Tried a different brand fit perfect
« Reply #7676 on: May 21, 2014, 12:19:56 AM »
I'd contact EBC directly and let them know of this issue.  Hopefully they have good service and will make it right.
I opened up another few boxes of parts that were shipped to me today.  I should have a few good updates this weekend.
« Reply #7677 on: May 21, 2014, 04:37:22 PM »
Made an appointment to get my ac fixed. This will be the third ac compressor installed since 2012. Hope this one sticks!!!!
« Reply #7678 on: May 21, 2014, 06:36:31 PM »
Have them flush your AC system. There could be debris in it that is damaging your compressors.
« Reply #7679 on: May 24, 2014, 01:48:10 PM »
Shipped my old grill out today..
Pages: « First < Previous 1 ... 510 511 [512] 513 514 ... 596 Next > Last »   Go Up
