August 29, 2026, 07:23:25 PM
509
510
511
512
Topic: What did you do to your Gen7 today? (Read 3684396 times)
Reply #7635 on:
May 03, 2014, 08:30:57 AM »
Replaced the fuel pump because car died the other day, we checked fuel pressure and got nothing. Took about 10 mins to change....car still ran funny no check engine light on the dash. Hooked it up to the Genisys....and found out the check engine light burnt out :
Cam Sensor - Intake
Cam Sensor - Exhaust
Crank Sensor
TPS Sensor
02 Sensor Upstream
02 Sensor Downstream
FML I picked up the 2 cam and crank sensor from work, had to order the TPS, and we are pretty sure the 02's are just fouled so we are going to clean those up.
Reply #7636 on:
May 03, 2014, 08:49:59 AM »
Could be a different issue if all those sensors went bad. None of that stuff is known for going bad except the TPS in swap cars with stuff mounts.
Reply #7637 on:
May 03, 2014, 09:27:45 AM »
Any thoughts on what else it could be? Car has a miss and refuses to idle properly, wants to stall when the clutch is depressed. I pulled a vaccum line to raise the idle just so I could drive it around without it trying to stall at every stop.
Also the car does have 310xxx km on her....
Last Edit: May 03, 2014, 10:16:36 AM by Rushzer0
Reply #7638 on:
May 03, 2014, 12:08:03 PM »
Something funky with the wiring or one damaged sensor that's affecting the other sensors that are on the same bus.
Reply #7639 on:
May 03, 2014, 08:34:21 PM »
I did a little work today...ROFL.
Reply #7640 on:
May 03, 2014, 11:54:23 PM »
Congrats Denny!! It's getting there!!
Reply #7641 on:
May 05, 2014, 10:33:32 PM »
Bought a new cabin air filter and some 20a fuses.
Reply #7642 on:
May 06, 2014, 07:48:51 AM »
Hit 140k miles on my way back from Philly.
Reply #7643 on:
May 06, 2014, 07:55:52 PM »
Got 20k on you bud.
Started the transformation on the exterior of the RDX. Hope to finish up this weekend then it's time for the Accord.
Reply #7644 on:
May 07, 2014, 08:14:43 AM »
Only 20k? I'll close that gap soon enough. lol
Pascal
Reply #7645 on:
May 07, 2014, 04:03:36 PM »
Why pay a lot of money for a direct fit short ram when you can do one with given filter and three collars. I cut the pipe because it was too long and made me a bracket so it doesn't just sit in the bottom and make contact noise. Sounds nice !
Reply #7646 on:
May 10, 2014, 12:06:20 AM »
Buying more parts for the headswap. Forgot to order the stupid egr crap and still need 2 gallon of type2 coolant.
Reply #7647 on:
May 10, 2014, 12:18:59 AM »
So now you're going through with it?
Reply #7648 on:
May 10, 2014, 08:04:20 PM »
Gave it a wash and wax before dropping it off tomorrow night.
Pascal
Reply #7649 on:
May 10, 2014, 11:06:51 PM »
Took the race car out to the race track to do some tests.
509
510
511
512
