August 29, 2026, 09:20:13 PM
510
511
512
513
Topic: What did you do to your Gen7 today? (Read 3684519 times)
olecram39
Reply #7650 on:
May 10, 2014, 11:58:58 PM »
This came in today
Reply #7651 on:
May 11, 2014, 01:59:56 PM »
Added 5mm spacers in the front the even out the offsets at about 38 all around. Also played with different firmness levels of the struts all in an effort to cut down on the understeering of running wider wheels in the rear. Ended up increasing the rear 2x and 1x in the front. I'll see how feels over the next few days.
olecram39
Reply #7652 on:
May 11, 2014, 04:33:37 PM »
got my in dash tablet setup done. Still needs some adjusting
Reply #7653 on:
May 11, 2014, 06:10:19 PM »
Yup going to go through with it. I might need your help and your garage. Thien said it's not too bad too do since I know how to do the Timing Belt for the j series. Just need to remover all the stuff and make sure of I am not missing screws when I put it back in.
Quote from: timot_one on May 10, 2014, 12:18:59 AM
So now you're going through with it?
Also happy mother day!
Reply #7654 on:
May 11, 2014, 07:24:03 PM »
Quote from: olecram39 on May 11, 2014, 04:33:37 PM
That's nice... any info on where you got the panel piece from, or is it custom made? I would love to do this with my Garmin
Reply #7655 on:
May 11, 2014, 07:49:20 PM »
Quote from: thisaznboi88 on May 11, 2014, 06:10:19 PM
Just let me know and I'll make sure I'm available.
Reply #7656 on:
May 11, 2014, 08:23:57 PM »
^ sounds good Tim. Thanks !
olecram39
Reply #7657 on:
May 11, 2014, 10:00:13 PM »
Tim I will be making a thread with all the info, so stay tuned for that
Reply #7658 on:
May 11, 2014, 10:09:06 PM »
Didn't do any work on my Accord today because I am still waiting on parts to show up for the block. However, I did spend a little time working on the Civic. Ran into an issue when I was driving it this morning. The motor started to miss and then cut out when I came to a stop. After checking into a few things, I pulled the plugs and discovered that they were fouled and worn like crazy. The gap on the plugs were twice what they should be. I picked up a new set of plugs and things were back to normal.
Reply #7659 on:
May 11, 2014, 10:24:03 PM »
Hit 190k today, and dropped it off at the body shop. I miss it already.
Reply #7660 on:
May 12, 2014, 07:57:18 AM »
Quote from: olecram39 on May 11, 2014, 10:00:13 PM
Billy
Fixed.
Reply #7661 on:
May 12, 2014, 11:21:57 PM »
After some delays, dropped it off at the body shop to start getting repaired, again... along with some other things that will be taken care of in the process.
--Dave--
NECM Squad
Profile & Mods List
2003 I4 Accord Sedan
Reply #7662 on:
May 18, 2014, 01:47:07 AM »
Couldn't sleep. Went out into the garage and took my front plate off. I had asked the shop to leave it off but they forgot. Temporarily zip tied it.
Reply #7663 on:
May 18, 2014, 09:37:59 AM »
Received my solid shifter bushings yesterday. Haven't installed yet.
Reply #7664 on:
May 18, 2014, 10:32:13 AM »
Pulled out my mock up motor from the Accord and got it on an engine stand. Now that I have the blower located in the engine bay, fabrication of the plenum should be pretty simple. I'm just waiting on the water to air core from Bell Intercoolers and then things can get started.
510
511
512
513
