August 29, 2026, 12:14:53 PM
Pages: « First < Previous 1 ... 478 479 [480] 481 482 ... 596 Next > Last »   Go Down
Author Topic: What did you do to your Gen7 today?  (Read 3684088 times)
« Reply #7185 on: September 26, 2013, 11:25:16 PM »
battery draining issue has returned. lol need to start driving longer. 5-10 mins trips are just not charging my battery. probably need to add a relay for the aem fic.
« Reply #7186 on: September 27, 2013, 01:55:34 AM »
I didn't mean it in a bad way Tim..  I was just asking because if you are anything like me, I sometimes just take things apart to see how they work or to see how I can make them better. And I can tell you know your stuff so that's what I meant. I didn't see your previous posts, my bad.
Gotcha.  My tranny has been apart a few times actually.  Once to install a LSD.  Another time because I knocked a few teeth off of 6th gear.  This time is to install a taller final drive and a '10 Si gearset.
« Reply #7187 on: September 27, 2013, 07:57:39 AM »
Started getting my fog light brackets setup the OEM adjusting springs suck so am looking for a more durable to fab something up. Also started to poly fill the front exhaust mount to stop it from hitting my underbody brace
« Reply #7188 on: September 27, 2013, 10:44:59 AM »
New ballasts going in today! Cheesy
« Reply #7189 on: September 27, 2013, 11:18:51 AM »
Replaced my pedal pads with grip tape. Also discovered I have some worn shifter parts causing some slop. Now to dismantle and upgrade as soon as I can find replacement parts.
« Reply #7190 on: September 27, 2013, 10:10:34 PM »
Look into the MTEC stuff.  They have a shifter spring and bushing replacement.  AFH carries their stuff, so you can order it from them.
« Reply #7191 on: September 27, 2013, 10:54:29 PM »
removed the stupid spark plug gasket from my TL-S valve cover. Found out the TL-S valve covers are made out of magnesium. Hmmm
« Reply #7192 on: September 28, 2013, 07:56:33 AM »
O rly? Thanks for the tip.
« Reply #7193 on: September 28, 2013, 05:02:14 PM »
Ran the wires for my Uego and vacuum line thingy that goes to the AEM FIC. Found out that some of the Ebay fog wires over heated, but lucky no fire.
edit*
Was bored so I disassemble my TL-S heads. So retainers, springs, and coller pins are all off. Still need to remove the valve seals, camshaft seals, and camshaft sensor.
Head will probably go on next semester. Tim I am going to need your garage and Josh's help in March or April if things go according to plan.
« Last Edit: September 29, 2013, 12:53:06 AM by thisaznboi88 » Logged
« Reply #7194 on: September 30, 2013, 06:39:19 PM »
Got a bluetooth OBD-II adapter over the weekend and started messing around. Plotted this data from my trip home from work on Saturday
Also found a P0113 and P0420 codes. must be why I occasionally a CEL
« Last Edit: September 30, 2013, 06:45:02 PM by Rich01 » Logged
olecram39
olecram39 pfffft.
« Reply #7195 on: October 01, 2013, 04:01:24 PM »
from this roll of 3M 8518 Overlamite Film i made myself a clear bra. Now i can leave my nose mask on for a bit longer without having to worry about it scratching the paint.
cant even see it when you look at the car.
« Reply #7196 on: October 01, 2013, 07:54:19 PM »
Installed white LED lights in the interior of the RDX. Snapped the clip on the bulb holder on one of the license plate bulbs
« Reply #7197 on: October 01, 2013, 09:20:47 PM »
Katie is going to kill you. Just sayin.
« Reply #7198 on: October 01, 2013, 09:42:22 PM »
Lol $10 part at majestic, but shipping is $10 also.  I'm gonna stop at honda in the morning n order it n still save about $5.
« Reply #7199 on: October 01, 2013, 09:56:17 PM »
I can pick it up and send it to you. Majestic is on my way home from work.
Pages: « First < Previous 1 ... 478 479 [480] 481 482 ... 596 Next > Last »   Go Up
