October 28, 2026, 05:08:29 AM
478
479
480
481
Topic: What did you do to your Gen7 today? (Read 3807091 times)
0 Members and 18 Guests are viewing this topic.
Reply #7170 on:
September 22, 2013, 06:55:57 AM »
Went to change the battery in my key, and the goddamn screw head stripped.
Reply #7171 on:
September 22, 2013, 11:14:43 AM »
Jeff that happened to me last year, i had to get a new one ....grrrr
Reply #7172 on:
September 22, 2013, 12:15:19 PM »
Installed new Matsushita Gen V ballasts. Both headlights back in business now.
--Dave--
NECM Squad
Profile & Mods List
2003 I4 Accord Sedan
Re: Re: Re: What did you do to your Gen7 today?
Reply #7173 on:
September 22, 2013, 01:54:49 PM »
[quote athor=cna link=topic=270.msg132098#msg132098 date=1379719827]
Tore my car apart wiring wise I think I fixed my headlight issue swapped out ballast and D2s adapters even bulbs they fire every time now back to workin on my fog projectors
[/quote]
Shit. I completely forgot to look that stuff for you Clemente. I'm sorry man.
[/quote]
It turn out to be a bad batch of ballast they both fried and killed My bulbs and relays useless , good thing I had a brand new set of 3fives amp versions with new d2s adapters and spare relays to fix issue . I also ended up using a spare set of 50w 5000k bulbs and my cut off is still as sharp and reliable as previous setups
Reply #7174 on:
September 22, 2013, 05:40:38 PM »
Glad you got it figured out Clemente.
Reply #7175 on:
September 22, 2013, 07:49:49 PM »
order a add-a-fuse for my UEGO
Reply #7176 on:
September 23, 2013, 07:21:05 PM »
I did this today. I'm just waiting on a new needle bearing to come in for my new final drive so I can put it all back together.
Reply #7177 on:
September 23, 2013, 07:45:01 PM »
Nice work Tim. What did you go with for a final drive? Another vehicle?
Reply #7178 on:
September 23, 2013, 09:15:01 PM »
You took pictures of tranny guts? :shifty:
Reply #7179 on:
September 23, 2013, 09:20:00 PM »
Damn that pretty Epik Tim. Want to help me install and LSD
jp jp
Reply #7180 on:
September 23, 2013, 11:29:32 PM »
I went with a 4.052 final drive from the Indian market CR-V. This final drive has been WPC treated. The second gearset you see in the picture is from a FA5/FG2, which should give me more even gear spacing. The TSX 6th gear is going on the Si gear set for better freeway driving. There's nothing epic about all this. I'm just trying to improve my car and expand my experience. Service manuals are the only reason why I was able to get it all apart. Getting it back together will be a different story. Let's hope I can put it all back together.
Reply #7181 on:
September 24, 2013, 11:28:45 AM »
Damn Tim, that is awesome! Is there a big difference between the FA5 6th gear and the TSX 6th gear?
olecram39
Reply #7182 on:
September 24, 2013, 01:20:44 PM »
Did something actually happen to the tranny or you just felt like taking shit apart?
Reply #7183 on:
September 25, 2013, 01:11:17 AM »
FA5 and TSX 6th gear are both 0.652. The gearset I have is just 1-5, which is why I'm swapping over 6th gear from my TSX gear set.
Nothing happened to my transmission. I'm also not
taking shit apart
just because I
felt like it
. If you re-read this part...
Quote from: timot_one on September 23, 2013, 07:21:05 PM
new final drive
...and this part...
Quote from: timot_one on September 23, 2013, 11:29:32 PM
...you would understand why I took my transmission apart.
olecram39
Reply #7184 on:
September 25, 2013, 04:46:30 AM »
I didn't mean it in a bad way Tim.. I was just asking because if you are anything like me, I sometimes just take things apart to see how they work or to see how I can make them better. And I can tell you know your stuff so that's what I meant. I didn't see your previous posts, my bad.
478
479
480
481
