November 05, 2026, 06:49:57 PM
437
438
439
440
Reply #6555 on:
March 23, 2013, 07:55:22 PM »
Outers. Got em both done. Just gotta get it aligned once I install the camber arms.
fatbastard
Reply #6556 on:
March 23, 2013, 09:17:34 PM »
what people do over here is replace the inner steering rack end together with the outer tie rod end to "save" on alignment.
-- Charles --
2005 Honda Accord 2.4L sedan
2011 Subaru STi sedan
06RockHead
Reply #6557 on:
March 24, 2013, 04:02:16 AM »
Changed my oil, bottled up a sample to go to Blackstone Labs, I'm interested to see what comes up. And I may have accidentally flushed and bled my brakes as well.
Reply #6558 on:
March 24, 2013, 02:12:58 PM »
Replaced my ps axle and upper strut mount. Then I cleaned the wheel in that corner of all the muck that got slung all over it.
Reply #6559 on:
March 24, 2013, 04:56:02 PM »
Top off my MT tranny fluid.
DreaminAccord
I <3 My Honda
Reply #6560 on:
March 24, 2013, 05:34:36 PM »
Took her for a drive to Tractor Supply Co. - she hasn't been driven for a week and fuck did she feel good compared to the Nissan I've had all week!
Ben
1st Honda!
Graphite Gray / Black Leather
Reply #6561 on:
March 24, 2013, 06:52:00 PM »
Picked up a fumoto quick drain valve to make my oil change easier >
Reply #6562 on:
March 24, 2013, 07:04:16 PM »
Went to the car wash, got a free one too! The attendant wanted to see if he fixed the car wash station. Filled up with gas....and I did this!!!!
Reply #6563 on:
March 24, 2013, 09:37:36 PM »
Attempted to swap out my door lock actuator to see if that fixed the unlock problem. The screw holdin it in started to strip so I gave up.
Oh and in the process locked my only set of keys in the car...
Called Progressive and Flo came and got me back in. It was bound to happen, but I think I'm lucky for havin the car 4 years with only havin one key and this only happenin once. Haha
Reply #6564 on:
March 24, 2013, 10:22:16 PM »
With those door lock actuators, you have to be super careful and use the right number Philips screwdriver bit. Use any other and it will strip. Door lock actuator failures are a common problems with the Accord, and its more and likely the culprit on why your door locks won't open or close. I believe its a number 2 bit screwdriver. You really have to put a lot of force down on the screwdriver and turn at the same time.
Reply #6565 on:
March 24, 2013, 10:59:09 PM »
I had to take mine out before. I used a #3 phillips screwdriver. Your best bet is to order a new screw and replace the one you messed up.
Reply #6566 on:
March 24, 2013, 11:07:06 PM »
Quote from: Toybaru on March 23, 2013, 06:57:29 PM
Outer or Inner? Outer is super easy, inners you need a special tool to remove.
I was able to do the inner tie rod without any special tools. Removing the tie rod was easier than putting the new on on. There is a washer that has the be bent in order to keep it from moving and changing the alignment. It was a bitch and a half to bend with the limited amount of space without fucking any other parts in the process.
Reply #6567 on:
March 25, 2013, 12:17:57 AM »
I highly recommend using that special tool, because you are suppose to torque down the inner tie rod to 75 ft. lbs.
Reply #6568 on:
March 25, 2013, 06:31:59 AM »
Good info guys thanks! Ill keep it in mind if I try to tackle it again.
It was my fault, I was still on a high from the success of the tie rods and thought I could jump into it without even really lookin into it. Bit more complicated than I thought. Haha
DreaminAccord
I <3 My Honda
Reply #6569 on:
March 25, 2013, 07:27:09 PM »
Custom wired up an OEM fog switch to my Spec-D fog harness
How-To: Custom OEM Fog Switch
Ben
1st Honda!
437
438
439
440
