November 06, 2026, 11:24:51 PM
436
437
438
439
Topic: What did you do to your Gen7 today? (Read 3817718 times)
Reply #6540 on:
March 22, 2013, 08:33:14 PM »
This weekend is going to warm up enough to do some work.
Reply #6541 on:
March 22, 2013, 08:58:01 PM »
It is?!?
Hmm. Well I have to check my power steering fluid tomorrow. My steering wheel was giving me some resistance and jerking around today. Hopefully it just needs some fluid and not a new pump.
Reply #6542 on:
March 22, 2013, 09:44:00 PM »
Quote from: CrackerTeg on March 22, 2013, 08:33:14 PM
Yeah we'll see about that lol
Quote from: Nit3h4wk C0uP3 on March 22, 2013, 08:58:01 PM
It is?!?
Maybe something in the front end Denny, ball joints, tie rod ends, etc.
fatbastard
Reply #6543 on:
March 22, 2013, 09:47:11 PM »
It is?!?
i can sense the utter excitement.
-- Charles --
2005 Honda Accord 2.4L sedan
2011 Subaru STi sedan
Reply #6544 on:
March 22, 2013, 10:01:46 PM »
When I got the car it had no power steering fluid, the girl at the garage told me to keep an eye on the power steering pump. She said it would make noise, and start to act funny. That was like a year ago, I don't check the fluid on a regular basis, I'm hoping that's all it is. My bushings in the front are cracked, if it doesn't need fluid, maybe they finally went. ...
Doing some research on this website that covers items in custom films..
Reply #6545 on:
March 22, 2013, 10:48:03 PM »
Quote from: Nit3h4wk C0uP3 on March 22, 2013, 10:01:46 PM
kind of like a pop. At some points.
Reply #6546 on:
March 22, 2013, 10:58:00 PM »
It feels like it slips for a second, and then it's back on track.
Bought an engine cover. Time to be an artist
Reply #6547 on:
March 23, 2013, 01:27:04 PM »
Ran the car for a few min, moved the steering wheel back and forth a few times, turned the engine off, and checked my power steering reservoir. The level is between the two lines where the book says it should be. Great. I'll keep an eye on it, at least there's no leak. Why is my steering funky!? New power steering pump looks like the 150$ range, 350 for oem.
Reply #6548 on:
March 23, 2013, 02:13:17 PM »
Quote from: Nit3h4wk C0uP3 on March 23, 2013, 01:27:04 PM
pump would make noise. Look at ball joints, tie rods and bushings.
Reply #6549 on:
March 23, 2013, 02:37:25 PM »
There is a faint whooshing sound when I turn...
Reply #6550 on:
March 23, 2013, 03:30:48 PM »
Installed my light weight crank pulley and belt tensor and new Gatorback belt , So far it feels great and responsive also the power steering feels smooth like butter . Now to start working on the Body work
Reply #6551 on:
March 23, 2013, 03:31:00 PM »
Bought two Moog outer tie rod ends and a third brake light bulb. Took the car in for the Power Steering hose recall and in the inspection they deemed my DS outer tie rod end unsafe. So I gotta do that, finally install my Ingalls rear camber kit and get it aligned. Thinkin about gettin an upper set of camber arms as well... might as well right?
Reply #6552 on:
March 23, 2013, 04:51:04 PM »
Yes.
Bought a new PS axle. Replacing that bitch tomorrow.
Reply #6553 on:
March 23, 2013, 06:47:34 PM »
One tie rod end down before dinner PS will get done after. Not nearly as hard as I thought they were. I think I'm learnin!
Reply #6554 on:
March 23, 2013, 06:57:29 PM »
Outer or Inner? Outer is super easy, inners you need a special tool to remove.
436
437
438
439
