April 25, 2026, 11:44:03 AM
202
203
Topic: What did you do to your Gen7 today? (Read 3456361 times)
0 Members and 27 Guests are viewing this topic.
Reply #3000 on:
June 07, 2010, 03:57:59 PM »
Went to court and had my tinted lights tickets thrown out and threw on another pair of tires that way I have a matching set. No more spinning my bald ass OEM michelins when it rains.
Reply #3001 on:
June 07, 2010, 04:19:10 PM »
Glad to hear that, Z. Back when I was on my bald ass Michelins and went on a drive to Tallahassee, my car hydroplaned 6 times.
Reply #3002 on:
June 07, 2010, 09:17:47 PM »
Quote from: "thisaznboi88"
Also tried to do my brakeline and flush. I didn't have the special wrench for it so not going to risk stripping it. Guess the lines will have to wait another week or so.
You mean a crows foot wrench?
Also I need someone to help me with clutch bleeding. I have am going to use my friend pump thingy to keep pressure while I bleed it, but where is the bleeder screw on the v6 6mt. And how do I know I am doing it right?
The bleeder is on the slave cylinder, which is on your transmission.
07CoupeBlue
Reply #3003 on:
June 08, 2010, 12:13:41 AM »
I actually just did my clutch yesterday. It might be hard to reach the bleeder screw on the slave cylinder. I know on mine, the bleeder screw is in the most inconvenient position with pretty much no way to reach it.
Isn't there also a check valve on the slave cylinders of most Hondas that you can take out to make the clutch a lot less vague? You might look into that if you're a spirited driver.
Julian
Reply #3004 on:
June 08, 2010, 02:04:04 AM »
He means a flare nut wrench..
EDIT: I think crows foot and flare nut are synonymous.
Reply #3005 on:
June 08, 2010, 03:36:14 AM »
Was going to bleed brakes and install the lines but way too hot by midday. 100 by 12pm. lol
Reply #3006 on:
June 08, 2010, 07:00:30 AM »
Mark, self pwnage is awesome!!
Julian, it's really not that hard to get to the bleeder valve on the slave cylinder. It is fairly accessible on a stock K24. I don't know of any check valve that you can remove from the master cylinder either. What do you mean about the clutch being vague? You think you could be a bit more descriptive about the problem?
Reply #3007 on:
June 08, 2010, 09:20:57 AM »
Quote from: "alpha"
Actually, I think you're right Mark. These bad boys here would be crow's foot wrenches:
Reply #3008 on:
June 08, 2010, 09:29:00 AM »
There was a thread on v6p discussing whether or not this mod can be applied to 7th gens:
http://tl.acurazine.com/forums/showthread.php?t=734300
Reply #3009 on:
June 08, 2010, 09:39:30 AM »
There's also a thread on DA that's discussing it and some have actually done it. I guess the J series clutch slave cylinders share the same part number. I just don't know if this applies to the K.
Reply #3010 on:
June 08, 2010, 09:46:53 AM »
Maybe it was on DA and not v6p, because just like everything else, when you actually want to go back and find the thread again, you can't find it, haha. I had to use google just to get the thread on Acurazine.
Reply #3011 on:
June 08, 2010, 11:13:49 AM »
Quote from: "alpha"
That's the first thing I thought of when I read crows foot.
Reply #3012 on:
June 08, 2010, 09:02:25 PM »
Friend came and picked up his headlights today. So I helped him install and wire it all up.
Reply #3013 on:
June 08, 2010, 11:00:50 PM »
intake installed. Waiting on those hybrid tails....
07CoupeBlue
Reply #3014 on:
June 09, 2010, 12:19:12 AM »
Well for a lot of people, I guess they might feel that the stock clutch doesn't really bite at a specific point. But basically, on some slave cylinders, there's a check valve that slows down the fluid return which slows down the clutch. If you take that out, you get much better shifts and the clutch action is a lot faster. In the case of the 8th gen Civics, people have reported that it really helps get rid of grinds. However, I looked on my slave cylinder and it doesn't have it so I don't know what other K series transmissions it applies to. From what I know, it's mostly a J series thing.
Julian
202
203
