September 28, 2026, 07:40:37 PM
199
202
Topic: What did you do to your Gen7 today? (Read 3745595 times)
Reply #2985 on:
June 01, 2010, 07:57:09 PM »
Ripped out my Grom Audio USB mp3 adapter to send it back for a replacement.
Replaced my Cabin Air Filter. Holy crap, how was the AC/ heating system was working correctly is beyond me. Anyway, installed new filter and the car is about 5lbs. lighter
Reply #2986 on:
June 01, 2010, 09:52:10 PM »
Had to get my front passenger side Toyo Proxes tire replaced (under warranty - phew) at Town Fair because I had a big nail in it from last week and the hole couldn't be patched because of how close it was to the sidewall. Now I have 1 brand new tire and 3 used ones, ::sigh::.
Z, I want your input on how you did the Seafoam in your car. I'm still iffy on doing it to mine.
--Dave--
NECM Squad
Profile & Mods List
2003 I4 Accord Sedan
Reply #2987 on:
June 02, 2010, 12:06:15 AM »
Dropped it off at the shop to get some exhaust work done.
Reply #2988 on:
June 02, 2010, 01:37:17 AM »
i cleaned my idle control valve and the results were awsome..it help out on the rough idle i was having..and i also got around to install the DRL kit i had laying around..
Reply #2989 on:
June 02, 2010, 01:49:50 AM »
Better than dino oil. For the k's at least. Not so much for the j's.
Mobil 1 5w30 shears to a 20 weight, according to UOAs on BITOG. (unless they changed their formula recently) Mobil 1 Extended Performance is a better choice if you wanted to stay with Mobil 1.
Quote from: "striktlyaccord"
Don't seafoam your car. It's bad for it.
Reply #2990 on:
June 02, 2010, 02:18:07 AM »
Use redline 5w20. The 20 weight is more like 30.
Reply #2991 on:
June 02, 2010, 08:29:15 AM »
Quote from: "alpha"
Really? I've used M1 on all my cars for the longest time. Thing is, I also change it at Honda's recommended interval so I don't leave it in there as long as others do.
Quote from: "alpha"
That depends on how you do it. Since I did mine (first time it's ever been done on my car and it has 84k), I've had a smoother idle and acceleration. I expect to get better mileage out of her as well since I'm doing mostly city driving now.
Dave, if you still want me to tell you how I did it, shoot me a PM.
Reply #2992 on:
June 04, 2010, 08:44:37 PM »
did my rear camber kit and made a video. Finally!! Its been sitting on my table for 2 months now.
Also tried to do my brakeline and flush. I didn't have the special wrench for it so not going to risk stripping it. Guess the lines will have to wait another week or so.
Also I need someone to help me with clutch bleeding. I have am going to use my friend pump thingy to keep pressure while I bleed it, but where is the bleeder screw on the v6 6mt. And how do I know I am doing it right?
Reply #2993 on:
June 04, 2010, 08:52:29 PM »
did a simple wash and wax
Reply #2994 on:
June 05, 2010, 08:18:01 AM »
Stripped all the paint off my IM and wire wheeled what the paint stripper didn't get. Looks like new.
Reply #2995 on:
June 06, 2010, 12:49:17 PM »
Rebled all my brakes, and while doing this I noticed the shims on the front outer pads were working their way off. So, I had to take the GS calipers off and put the shims back in place. I hope they don't move their way back out. I also washed my car.
Reply #2996 on:
June 06, 2010, 02:17:40 PM »
Quote from: "Jeff"
Shims have a tendency to move and come off. I don't use shims for that reason.
Reply #2997 on:
June 06, 2010, 04:07:30 PM »
That's why I use brake goo.
Reply #2998 on:
June 06, 2010, 07:14:52 PM »
Polished the headlights and took apart the dash to move around some wires.
Reply #2999 on:
June 06, 2010, 08:15:16 PM »
Started making a HID wire harness for my fogs and had to stop because of rain. Looks like I'll be going in early to work in the morning
199
202
