September 26, 2026, 03:20:53 PM
Pages: « First < Previous 1 2 [3] 4 5 Next > Last »   Go Down
Author Topic: How To: Install Headers  (Read 61667 times)
« Reply #30 on: May 02, 2010, 10:36:25 PM »
No worries. I'm one of those that breaks shit off if its in my way and I don't need it.
fabulous010 pfffft.
« Reply #31 on: May 06, 2010, 08:14:50 PM »
I just installed the headers and was wondering if that whistle is normal? Engine makes an annoying whitsle when a press throttle moderately???
fabulous010 pfffft.
« Reply #32 on: May 06, 2010, 09:00:15 PM »
I did some research and apparently the o rings are pretty crap. I think I was the lucky one and got a bad o ring, which doesn't make a perfect seal. So I will now have to order some o ring gaskets. Boo
Edit: I don't know if it might be the flex pipe or just a bad o ring. Do you guys have any suggestions on how to diagnose the problem area?
Icebox pfffft.
« Reply #33 on: May 07, 2010, 07:05:17 AM »
with the car running, spray a soap/water solution on the possible problem areas to see if there is a leak
fabulous010 pfffft.
« Reply #34 on: May 07, 2010, 05:26:12 PM »
Ok thanks I will try that, hopefully this weekend.
« Reply #35 on: May 08, 2010, 08:00:29 AM »
The other thing that you could do is get a mechanic's stethiscope and use that in the area where you suspect the exhaust leak.  That's what they use at most exhaust shops.  Hopefully it's the o-ring gasket though.
fabulous010 pfffft.
« Reply #36 on: May 08, 2010, 06:34:51 PM »
Today after I changed my spark plugs, I went and checked my header to see if anything was loose and found one bolt near the top of the motor loose. so I tightened it. All other nuts and bolts were secure. So I thought that one loose bolt was the culprit of my problem. But after taking a test drive the hiss was still there. So I will to try something else. I don't have much time to be going to a mechanic shop. Soo, I was thinkig if I can grab exhaust tape and wrap the flex pipe in it. Then hopefully I can narrow it down to two things: If the hiss goes away then I know it's the flex pipe. If the hissing remains then it would have to be an o ring gasket. what do you guys think?
p.s can i even you use any kind of tape just to take it around the block to test it?
frostnyc
frostnyc pfffft.
« Reply #37 on: May 27, 2010, 02:27:15 AM »
So post header install, after a few minor issues, my car sounds very very raspy at low RPM's. I'm not sure what could be the culprit other than a loose bolt (no whistles, it's just raspy as hell), OR the fact that the rest of my exhaust is still stock, and the stock equipment just doesn't sound good with the extra free'd up airflow. Also, my cat is SULEV... not sure if that has anything to do with anything. Car is a i4 AT. Other breather mods include Fujita CAI and TSX IM.
« Reply #38 on: May 27, 2010, 06:54:48 AM »
Where is the "raspy" noise coming from?  Your muffler, or around the header?
frostnyc
frostnyc pfffft.
« Reply #39 on: May 27, 2010, 11:33:28 AM »
I *think* it's coming from around the header, because the sound is amplified when I'm next to other solid objects (i.e. other cars, dividers, etc.). Another thing I should probably mention is I'm still using a broken o2 sensor. My original fell out and got destroyed. I don't think that has anything to do with it, but I have a new one coming in the mail so I can finally get rid of this CEL.
« Reply #40 on: May 27, 2010, 12:29:07 PM »
Do you have anything plugging the hole for the primary a/f sensor on your header right now?
Icebox pfffft.
« Reply #41 on: May 27, 2010, 12:33:13 PM »
Quote from: "frostnyc"
frostnyc
frostnyc pfffft.
« Reply #42 on: May 27, 2010, 02:24:59 PM »
yes, the broken one, so it doesn't sound like a ride-on lawn mower (there's no mistaking the sound when that thing pops out). now it only sounds like one of those push mowers.
« Reply #43 on: May 27, 2010, 02:35:15 PM »
From the description, it sounds like a bad leak from one of the junctions and not the flex pipe. You might have a blown gasket or that o2 sensor isn't plugging up the hole very well. If you were to lay down next to your car and listen for it, it'd help you and us determine what the problem is. Another question I have is if there are any mods to the stock exhaust (I.e. removed resonator) or is it unmolested?
frostnyc
frostnyc pfffft.
« Reply #44 on: May 27, 2010, 03:24:35 PM »
The stock exhaust remains unmolested..
Pages: « First < Previous 1 2 [3] 4 5 Next > Last »   Go Up
