January 30, 2026, 05:38:46 PM
[Profile] timot_one
30
31
32
33
39
Topic: [Profile] timot_one (Read 321825 times)
Re: [Profile] timot_one
Reply #450 on:
December 12, 2012, 12:11:07 PM »
Shit's weak.
Reply #451 on:
December 12, 2012, 12:25:32 PM »
I can't wait to get the mid pipe cut and rewelded so I can fire it up and have a quiet car again.
Reply #452 on:
December 12, 2012, 12:50:31 PM »
Its coming together nicely
Reply #453 on:
December 12, 2012, 01:06:39 PM »
Thanks Clemente. I'm hoping to have the exhaust finished up tonight and the electric cut out valve on by tomorrow night.
Reply #454 on:
December 12, 2012, 08:57:38 PM »
Looking good so far Tim, great job man
Reply #455 on:
December 12, 2012, 10:08:06 PM »
Exhaust will be done Friday night. My welder is busy and won't be able to get it done until then. I also discovered that there's a problem with my kpro. It's not reading the VSS signal. I tested a different kpro tonight and it reads the VSS fine. I'm going to have to buy another ECU to have the kpro swapped to, along with the signal conversion module so I don't have to run a dual ECU.
I got my supercharger back on and bled my aftercooler set up. One of my fittings is leaking coolant. I have to drain the coolant, remove the line and replace the fitting. It's not that bad, but it's just going to be a bit tedious.
Reply #456 on:
December 13, 2012, 12:17:28 AM »
No more dual exhaust?
--Dave--
NECM Squad
Profile & Mods List
2003 I4 Accord Sedan
Reply #457 on:
December 13, 2012, 08:08:35 AM »
No, I still have the same exhaust. That's the set up for my exhaust cut out. Now I'll have it quiet when I want, and more power when I need it.
Reply #458 on:
December 13, 2012, 09:18:39 AM »
Quote from: timot_one on December 12, 2012, 10:08:06 PM
thats a new developement, i thought you were always opposed to the single ecu setup. im real curious to see how you do it and retain the stock gauge cluster.
Reply #459 on:
December 13, 2012, 09:20:51 AM »
I don't think he was opposed to it. I think he was opposed to the mass of wiring to make it work without hiccups.
Reply #460 on:
December 13, 2012, 09:59:18 AM »
that is why i paid paul to take care of it for me.
Reply #461 on:
December 13, 2012, 01:59:52 PM »
Quote from: timot_one on December 12, 2012, 11:49:45 AM
Here's the damaged flex pipe. Kinda bad for it only being on my car for 7 months of use. It sat in my garage for a year and a half.
Holy shit! That thing looks really bad. That type of damage should not occur from typical operation; it looks like premature failure due to either a manufacturing defect or poor build quality.
Reply #462 on:
December 13, 2012, 04:36:38 PM »
I was never opposed to one ECU. I wasn't a fan of using a RSX gauge cluster for various reasons. The module I have I probably the only one that will be made. It's a signal converter so the KPro ECU can send the correct signal to the Accord gauge cluster.
Reply #463 on:
December 14, 2012, 09:35:25 AM »
i would love to get my hands on one of those. as ive told you before, the gaps that i have due to rsx cluster are really starting to annoy me and i would like to switch back to a stock cluster if possible. i would have to change a couple of other things to make it work like yours but it would be worth it to have a cleaner look.
Reply #464 on:
December 15, 2012, 04:16:46 PM »
I have been trying to get these made for Accord owners. All I can do is be persistent and let them know there is a market for them.
30
31
32
33
39
