June 13, 2026, 02:15:24 AM
[Profile] timot_one
Topic: [Profile] timot_one (Read 357294 times)
[Profile] timot_one
March 27, 2008, 09:16:23 PM »
About Me:
Real Name:
Timothy
Troy, OH
Occupation:
Regional Account Rep / MECP Licensed Installer
Interests:
cars (import, euro, muscle, classic); music (listening, playing, writing, recording); audio systems; cooking
About My Car:
Model:
2003 CM55 LX
Color:
Satin Silver Metallic
Engine:
K24A
Tranny:
CL9
MT
News:
The head was dropped off to get ported and polished on 03/11, after that it will be going to the machine shop to get the valve guides honed, a valve job done, and will be decked. I should be picking it up when I get back from my vacation. I also received my block back from ERL Performance on 03/15. When I get everything back, I'll be claying the motor to figure out if I can use an OEM thickness head gasket, or if I need something a little thicker.
Current Mods:
Engine/Drivetrain
AEM CAI
RSX Type S Throttle Body
Comptech RSX Type S Supercharger
3" Pulleyboys Supercharger Pulley
J.Mercado Aftercooler (removed to test Noribilt Aftercooler)
NoriBilt Prototype Aftercooler
Front Mount Heat Exchanger
AEM Water/Methanol Injection
IPS KSC '11 Cams
K20A2 50º VTC Gear
OEM Lightweight Exhaust Cam Gear
Hybrid Racing Timing Chain Tensioner
Aeromotive FPR
Braided Fuel Lines
Hybrid Racing Fuel Rail
RC 750cc Injectors
Hasport Intake Manifold Adapter
4-1 SS custom header with 1 7/8" primaries
Magnaflow 3" Metal Spun High Flow Cat
3" Mid Pipe with Magnaflow 30" resonator
2.5" Magnaflow Mufflers (dual)
OEM TSX Exhaust Tips
Comptech Short Shift Kit
Shortened Shifter
Solid Brass Transmission Bushings
RSX Type S 14 lb Flywheel
Competition Clutch Stage 4 Clutch
TSX 6 Speed Transmission
OBX LSD
Hondata KPro
Modifry Yellowjacket
AEM UEGO Wide Band O2 Gauge
AEM Oil Pressure Gauge
AEM Boost Gauge
PLX DM-200 60mm Gauge
PLX DM-200 OBD 60mm OBDII Gauge
PLX SM-AIT sensor
PLX SM-FLUID sensor
Suspension/Brakes/Wheels
Tein Comfort Sport coil overs
Comptech 22 mm rear sway bar
TL Type S 27.5 mm front sway bar
Ingalls front and rear camber kit
Neuspeed front shock tower bar
OEM V6 6MT front shock tower bar
Cusco Type II chassis brace (removed for header clearance)
Ichiba v2 15mm spacer (for front Buddy Club wheels to clear RL calipers)
Buddy Club P1 Racing SF 18"x7.5" +42 wheels (summer)
BF Goodrich g-Force Sport 245/40/18
Enkei ZR2 18"x7.5" +42 wheels (winter)
Bridgestone Blizzak LM-25V 225/45/18
Acura RL 4 Piston Calipers
Rotora 13" Rotors (front)
Rotora Honda Pilot Rotors (rear)
EBC Yellowstuff Pads
Rear Drum to Disc Conversion
Exterior
35% tint all around
'03-'05 ASEAN Accord Grille (custom painted)
Shaved Door Moldings
OEM Wing Spoiler
OEM HFP Coupe Front Lip
OEM HFP Coupe Rear Lip
TSX Mirrors
Shaved Honda "H" / Accord / LX badges from trunk
Lighting
OEM Housings retrofitted with S2000 projectors
Philips Gen3 ballasts w/ Philips 4300k D2S bulbs
HID kit with 5000k bulbs (high beams)
1st Gen MDX Fog Lights with DDM HID kit with 3000k bulbs
Interior/Electronics
Civic Type R Shift Knob
ICE
Multimedia
Alpine IVA-W505 7" Multimedia DVD h/u
Alpine P1 Navigation
Alpine PXA-H701 5.1 Dolby Pro Logic II & DTS Surround Sound Processor
Alpine VPE-S431 Video switcher
Alpine KCE-415i iPod Video Interface
Alpine TUAT020XM XM Tuner
Apple 6th Gen 160 Gb iPod Classic
Apple 5th Gen 60 Gb iPod Video
Sony DVX-11A DVD player
Reverse camera in tail light key hole
Sony XVM-R75 7" Motorized Flip Down Monitor (headliner) (x2)
disconnected
Sony XVM-H65 6.5" Monitor (headrest) (x2)
disconnected
Sony XVM-H6 5.8" Monitor (sun visor) (x2)
disconnected
Amps
McIntosh MC431 4x100 watts (out for repair)
McIntosh MC440 2x100 watts + 4x50 watts
McIntosh MC443 1x300 watts @ 4Ω
Speakers
Elemental Designs e3.6 6.5" Midbass Subwoofer (doors)
MB Quart QM215.61Q 5.25" Midrange (kick pods)/1" Tweeter (sail panel)
MB Quart QM218.61Q 6.5" Midrange/1" Tweeter (center channel)
MB Quart QM215.61Q 5.25" Midrange/1" Tweeter (rear deck)
JL Audio 13TW5 13" shallow mount subwoofer
In Progress:
Engine/Drivetrain
My New Engine Build:
ERL Performance K24A2 Sleeved Short Block w/88mm bore
ARP Main Studs
ACL Bearings
Manley Turbo Tuff Rods
CP 11.1:1 CR Pistons
K20A2 Oil Pump
Honda Oil Pump Chain
K20A2 Head w/Light Port and Polish
ARP Head Studs
Cometic Head Gasket
Ferrea Valve Guides
Ferrea 6000 Series 35mm Intake Valves
Ferrea 6000 Series 30mm Exhaust Valves
Ferrea 105lb Valve Springs
Ferrea Retainers
Ferrea Retainer Keepers
IPS KSC '11 Cams
K20A2 50º VTC Cam Gear
K24A4 Exhaust Cam Gear
Honda Timing Chain
Circuit Hero Lower Timing Chain Guide
'07 Civic Si Upper Timing Chain Cover
K20A2 Water Pump
K20A2 Oil Cooler
Hybrid Racing Oil Cooler Hoses
Hybrid Racing Coolant Hoses
Hybrid Racing 74mm Throttle Body
Work CR-KAI 18"x8.5" +43mm
Exterior
ASEAN Front Bumper and Grille (waiting for paint)
Interior/ICE
Alpine TME-M740BT 7" Touch Screen Monitor molded in the OEM upper dash mount
Future Mods and Plans:
Engine/Drivetrain
Eaton/Magnum Power MPx90
Ultra Racing Chassis braces
Exterior
Mugen front lip
Lighting
TL headlight retrofit with custom molded bezels
FX headlight retrofit in blackhoused '03-'05 Inspire housings
LED tail light retrofit
Interior/ICE
Alpine PKG-M780 Dual 7" monitors (x3[sun visors/front seat headrests/rear seat headrests])
Alpine PKG-RSSE2 10.2" monitor w/DVD player (x2[headliner])
New Trunk Set Up
Car History:
Bought used with 27k on it in July of 2004 from Honda Village in West Newton, MA (worst dealership ever). It replaced my 1991 VW 16v GTi.
In the beginning of December of 2004 I was hit by an inexperienced driver that didn't understand the concept of stop signs, turn signals, or which cars had the right of way. She t-boned me as I was turning left in front of her, which caused damage to my left rear door and quarter panel.
Within the first month of owning my car, I have been upgrading the audio system. It has been evolving slowly since then to what it is right now, but is still far from completion.
Pictures:
Last Edit: March 18, 2012, 01:03:11 PM by timot_one
Re: [Profile] timot_one
March 28, 2008, 12:08:10 AM »
Superb profile Timmy.
April 01, 2008, 01:23:23 AM »
I've modified this nasty bitch! On more than one occasion
03 CM55 NBP
MT
April 01, 2008, 04:16:36 AM »
Awesome profile Tim! Your car is looking great!
JC04accord
April 03, 2008, 07:58:43 PM »
I've ridden in that nasty bitch, hurry up and finish your TL retro already jeez slacker.
February 04, 2009, 03:19:32 PM »
Nice list of audio!
February 04, 2009, 04:09:37 PM »
I need to update that list and add a few new pictures.
February 04, 2009, 05:07:38 PM »
Mod list updated. New pics posted.
lilmalu
February 05, 2009, 01:06:35 AM »
Tim, the ride looks suber duber. I'm going probably copy the coupe lip as now it caught my attention.
Elite Profile
Cardomain Profile
February 05, 2009, 08:42:21 AM »
I stole that idea from Skippy. When I saw the coupe lips on his car, I had to have them.
lilmalu
February 05, 2009, 09:15:40 AM »
The idea is not bad, its just. I'm thinking of either swapping bumpers with a coupe or just putting the coupe lip on alone.
Elite Profile
Cardomain Profile
February 05, 2009, 12:14:46 PM »
The coupe front bumper will not fit very well. You're better off just using the coupe front lip.
lilmalu
February 05, 2009, 02:57:28 PM »
Would the bumper need major modification, or something simple like the coupe lip fitting on the sedan bumper?
Elite Profile
Cardomain Profile
February 05, 2009, 03:17:16 PM »
It just won't fit properly since one is wider than the other. I forgot which though.
lilmalu
February 05, 2009, 03:24:21 PM »
ohh snap....coupe lip it is
Elite Profile
Cardomain Profile
