August 26, 2026, 09:17:42 PM
Author Topic: Deep Gloss Auto Salon: E60 M5 - Glossorama!  (Read 12721 times)
Deep Gloss
Deep Gloss pfffft.
« on: May 09, 2009, 10:53:17 PM »
E60 M5 –Interlagos Blue
This vehicle was dropped of for full paint correction, Working with Interlagos Blue is always a treat. It is such a vibrant and dynamic palette when corrected.
Before Pictures:
As you can see, the vehicles paintwork looks dull, flat and lifeless. If you are familiar with the potential of BMW Interlagos Blue, you know how magnificent it looks when properly detailed.
As with every job I always begin by cleaning the wheels and rims. Below are the products used and some in process pictures:
Wheels/Rims/Arches Process:
P21S Wheel Gel
Laitner Brush (powered by drill)
Meg’s APC for tires
Meg’s Super Degreaser on Arches
P21S being applied:
P21S Dwelling:
Laitner Wheel Brush in Action:
Rinse:
Q-Tips for Small Areas:
They Had a Good Life:
Before:
After:
On to cleanse the paint
Paint Cleansing Process:
Pressure washed
Surf City Grime Destroyer to lower half of vehicle
P21S Total Auto Wash sprayed on upper half of vehicle
Pressure Washed
Foamed with Chemical Guys Clear Wash via Foam Cannon
Pressure Washed
Two Bucket Wash with Meguiars Hyper Wash
Pressure Washed
Below are some paint cleansing in process pics
Grime Destroyer Dwelling
P21s Total Auto Wash
Foam after about several minutes of dwell time
Rinsing off the foam
Two bucket wash
Cleaning the arches:
Embedded Contaminant  were removed from paintwork and rims with Riccardo yellow clay using ONR as clay lube. The paintwork had low levels of embedded contaminants.
Claying Paintwork
Clay after one panel:
Embedded contaminants were also removed from the rims:
Clay after one rim:
Exhaust tips were cleaned with blue magic metal polish and #0000 Steel Wool and then further refined with Surf City Maximum Metal (pics are before Max Metal application)
Before:
After
When the hood was popped it was observed that the dual K&N filters were not quite as tight as they should be. That was also taken care of:
Loose (see gap):
Tight:
Well now that that vehicles paint work was all clean, it’s time for some pictures of the defects present. I started this job at 8pm at night so all pictures of defects were done via halogens – no worries, the sun was bright and full for post correction inspection!
As you will see, this paintwork had an assortment of defects from swirls, marring & scratches. All of these defects are what cause the dull, lifeless appearance of the vehicle as delivered.
I have yet to master capturing defects when the sun is not available, below is a sample of what I was able to capture which does not fully convey the condition of the clear coat.
Paintwork Correction: I spent a good hour playing with different combo before settling on the below process - this clear was hard as nails
Meguiars 105 Via 3M Wool
Menzerna Super Intensive Polish via LC orange pad
Menzerna Super Intensive Polish via green LC medium polishing pad
Menzerna 106ff via white LC Polishing Pad
Menzerna 85rd via black LC pad
By the time the Makita was fired up, I had lost my photographer as it was pretty late. When I am on my own taking pictures is not my 1st priority as I charge by the hour and exhausting that time to take pictures would not be prudent. Below are two pictures I did manage to take while correcting the clear coat:
Before:
After M105:
Before:
After M105:
After I was done with correction it was well past the night and into the morning… Below are some post correction shots with no lsp:
Last Step Product(s):
For this step I decided to go with a Zaino treatment. 3 layers of Z2 that was enabled with ZFX was used. After each layer of the Z2 was removed, the paintwork was wiped with Z6. After the final layer of Z2 was removed a final wipedown of Z8 was used:
Finishing Touches:
1z Gummi Pfledge for weather stripping
Arches dressed with Undercarriage spray
Tires dressed with Surf City Tire Pro
Glass Cleaned with Surf City Clearly Better
Brightwork treated with Duragloss 501
Rims treated with 3 layers of Z2
A few sun shots – she is such an unforgiving mistress
Final product pictures:
Below are some High Dynamic Range pictures courtesy of  Milan Vincent (milanvincent.com):
Pictures cannot truly do this color justice as when you view it from different angle is changes shades of blue and even to purple. The owner made notice of this for what I thing was the first time in his ownership.
Thanks for looking.
Anthony212
Anthony212 pfffft.
« Reply #1 on: May 09, 2009, 11:19:50 PM »
one word wow
« Reply #2 on: May 09, 2009, 11:23:31 PM »
I'm very speechless with the kind of work you've done for your customers. Your very inspiring for me to start getting real serious with detailing my car. appreciate you taking the time that you show your work here. excellent job as always man.
mnkyman
mnkyman pfffft.
« Reply #3 on: May 09, 2009, 11:50:42 PM »
looking good as usual. How many hours did you spend on this car and how much was the total charge? Did you seriously work on this car from 8pm through the next morning...that's some damn commitment right there...
Sam -|- 2006 I4 Sedan SE
Deep Gloss
Deep Gloss pfffft.
« Reply #4 on: May 10, 2009, 06:40:02 AM »
Quote from: "Anthony212"
one word wow
Ha ha, thanks Anthony
Deep Gloss
Deep Gloss pfffft.
« Reply #5 on: May 10, 2009, 06:41:19 AM »
Quote from: "Ryann84425"
Thanks Ryan... glad I have have passed along the ocd bug to you... It is very rewarding....
Deep Gloss
Deep Gloss pfffft.
« Reply #6 on: May 10, 2009, 06:43:06 AM »
Quote from: "mnkyman"
Thanks... Cool
« Reply #7 on: May 10, 2009, 07:27:06 AM »
Thats dedication right there! But it helps you get reimbursed lol
I can't believe the transformation...awesome job once again.
Reputation Power: 25
« Reply #8 on: May 10, 2009, 08:23:22 AM »
Wow! That looks great. I love that car and color. I want a foam cannon. Isn't it a V10? It seems like you do several high end cars frequently, do you get to drive them all?
« Reply #9 on: May 10, 2009, 09:38:02 AM »
Your the freaking man great work like always
mnkyman
mnkyman pfffft.
« Reply #10 on: May 10, 2009, 12:34:21 PM »
Oh ya, what is the point of spraying the car with suds and rinsing and then doing 2 bucket? Just getting of the hard debris?
Deep Gloss
Deep Gloss pfffft.
« Reply #11 on: May 10, 2009, 12:59:43 PM »
Quote from: "slipkord"
thanks.... I do the same for my vehicle, when it needs it that is which as a result of sound maint techniques I only need a very light polish once a year
Deep Gloss
Deep Gloss pfffft.
« Reply #12 on: May 10, 2009, 01:02:13 PM »
Quote from: "wtcii"
Thanks... ya, this beauty is sporting a V10 with sounds very healthy thanks to the aftermarket exhaust.
I do not drive them except in and out of my driveway and then across the street for photos. Too much liability.. I know my driving skills are good but too many idiots out there..
Deep Gloss
Deep Gloss pfffft.
« Reply #13 on: May 10, 2009, 01:08:05 PM »
Quote from: "cna"
Thanks cna!
Deep Gloss
Deep Gloss pfffft.
« Reply #14 on: May 10, 2009, 01:10:35 PM »
By the time my mitt touches the paint my goal is for the vehicle to be as clean as possible which, reduces the chance to induce defects.
