November 06, 2026, 05:00:55 PM
Author Topic: Throttle body bypass  (Read 37424 times)
« on: April 29, 2009, 08:10:40 PM »
Does anyone know where the TB Bypass DIY is or if it has been brought over? I searched for it but no luck
« Reply #1 on: April 29, 2009, 11:11:16 PM »
I think the old forum is now gone.  I forgot what it is, but it's pretty easy to pull off.
« Reply #2 on: April 29, 2009, 11:21:37 PM »
Does the Fact that I am DBW make a difference? I re-attempted it again today and ended up confused like no other
Icebox pfffft.
« Reply #3 on: April 30, 2009, 08:40:52 AM »
http://www.k-series.com/tech_document.php?id=33
« Reply #4 on: April 30, 2009, 01:39:29 PM »
Do you have the i4 or v6? I did it on my v6 and all I had to do was disconnect the stock lines to the throttle body and connected them to each other using a hose  mender
Icebox pfffft.
« Reply #5 on: April 30, 2009, 01:44:39 PM »
based on his signature, im guessing i4.
« Reply #6 on: April 30, 2009, 02:46:42 PM »
what does this actually do for our engines? (i have a v6)
Icebox pfffft.
« Reply #7 on: April 30, 2009, 03:01:15 PM »
the only difference is that it may allow your motor to run a little cooler. i dont think it actually adds any power.
« Reply #8 on: April 30, 2009, 03:32:32 PM »
I felt a bit more respond from my acceleration and a smoother ride on hot days the car takes a little longer to warm up but never had a problem with it easiest mod I have done
fabulous010 pfffft.
« Reply #9 on: May 01, 2009, 10:13:52 AM »
did you have to drain the coolant at alll?
« Reply #10 on: May 01, 2009, 10:24:16 AM »
Nope didt have to drain any coolant i took a plastic cup and caught the little bit that fell and just re added it
Icebox pfffft.
« Reply #11 on: May 01, 2009, 10:28:14 AM »
very wise
« Reply #12 on: May 03, 2009, 05:50:06 PM »
well, turns out the tb lines were not the cause of my car overheating... For some odd reason the thermostat decided to go bad
Skippy pfffft.
« Reply #13 on: May 03, 2009, 06:47:40 PM »
For anybody wishing to do this modification, a few words of caution...The coolant lines running through the throttle body serve an important purpose.  They provide essential heat to the Idle Air Control Valve to keep it from sticking in cold weather.  If you remove the coolant loop from the IACV, you run the risk of having the valve stick on cold days.  This will make your idle fluctuate and the car will sound very ill.  You may attempt this mod if you live in a no-snow state, but I still would not recommend it.  I have not done this mod simply because I don't want to get caught with my pants down when the cold weather comes around..
03 CM55 NBP 6MT
NWINNIE34 pfffft.
« Reply #14 on: May 03, 2009, 08:01:48 PM »
i almost did this "mod" or whatever over the weekend when i installed oil catch can
didnt wanna deal with it
i did shorten the coolant line due to the disconnection of the engine vent hose from the CAI tube connection...didnt make ssense to keep that 4 way piece involved in the equation
