April 27, 2026, 01:23:26 PM
Pages: « First < Previous 1 ... 5 6 [7] 8 9 10 Next > Last »   Go Down
Author Topic: [Profile] Icebox - New Ride!  (Read 123898 times)
Icebox pfffft.
« Reply #90 on: October 18, 2011, 10:32:58 PM »
i guess worst case scenario....bye bye power steering.
« Reply #91 on: October 18, 2011, 11:08:16 PM »
Worst case scenario would be that you swap over to an electric power steering pump from a MR2.  All you really need is 12v and ground to the pump with a relay that's switched on when your car is in run.  Either that, or you can get the DC5 manifold.
Icebox pfffft.
« Reply #92 on: October 19, 2011, 10:57:36 AM »
what would be the estimated cost to do that ehps conversion?
« Reply #93 on: October 19, 2011, 07:53:30 PM »
I'm not sure.  I know that the biggest cost would be the pump and a mounting bracket fabricated.  Other than that, you'll need to convert your lines or get adapters for the pump.  Karcepts makes a mount and a line with the adapters.  Here are the links:
http://www.karcepts.com/shop/product.php?id_product=51
http://www.karcepts.com/shop/product.php?id_product=52
...and here's the link of their install:
http://www.k20a.org/forum/showpost.php?p=117238&postcount=1
Here's a few threads on k20a for the EHPS conversion:
http://www.k20a.org/forum/showthread.php?t=1597
http://www.k20a.org/forum/showthread.php?t=58599
http://www.k20a.org/forum/showthread.php?t=57308
Icebox pfffft.
« Reply #94 on: October 19, 2011, 08:21:45 PM »
ive been reading up on it today, seems like it would be more cost effective to just order another manifold from moss.
« Reply #95 on: October 19, 2011, 08:36:35 PM »
Very true.  I've been considering doing the conversion to free up some power.  In the same respect, I have also been looking into an electric a/c compressor conversion from a (ughhhhh) Prius.
Icebox pfffft.
« Reply #96 on: October 20, 2011, 11:13:54 AM »
that sounds like an interesting idea, but the parts are pretty expensive. how would you integrate that into the existing ac system.
« Reply #97 on: October 20, 2011, 11:55:48 PM »
Essentially, it would take the place of your mechanical a/c compressor, which is belt driven, with an electrical a/c compressor.  The basic idea of the pious a/c compressor and the mr2 ps pump is to reduce parasitic losses.  It's the same principle with running an electric water pump.  The parasitic losses from spinning the alternator to generate the electricity to power the pumps is much less than if you were spinning the mechanical accessories.  At least there's a kit to switch to an electrical water pump, but it's like $600-700 with the block off plate and other crap.
I wish I had the money to swap out the mechanical accessories with electrical versions.  Then at that point, all I would be running with the crank is the oil pump, alternator, and blower.
Reputation Power: 10
NVA-AV6 pfffft.
« Reply #98 on: October 23, 2011, 10:57:46 AM »
Ok, I see the PS pump to electric since it always pulls "some" hp, not much unless turning at low speeds. Now the AC is a complete waste, when the compressor in not engauged it has the same parasidic loss of a idler pulley (NONE!).
« Reply #99 on: October 23, 2011, 04:35:59 PM »
But what if it's a hot day Paul?
NVA-AV6 pfffft.
« Reply #100 on: October 23, 2011, 06:55:02 PM »
How about I just give you a hot pile of shit to eat........
Icebox pfffft.
« Reply #101 on: October 23, 2011, 08:27:18 PM »
hahahahahaha
« Reply #102 on: October 23, 2011, 08:48:58 PM »
ROFL!!!!
Icebox pfffft.
« Reply #103 on: October 23, 2011, 09:24:13 PM »
finally got around to taking a photo........
« Reply #104 on: October 23, 2011, 11:33:33 PM »
You already pissed in my corn flakes, so go right ahead Paul.  Hahahaha.
David, is your manifold like this?
Pages: « First < Previous 1 ... 5 6 [7] 8 9 10 Next > Last »   Go Up
