September 28, 2026, 03:19:13 PM
Pages: « First < Previous 1 ... 13 14 [15] 16 17 18 Next > Last »   Go Down
Author Topic: Check Engine Light Codes Discussion  (Read 175483 times)
« Reply #210 on: September 02, 2013, 10:20:10 PM »
No ideas on why but, you maybe able to clean it. Some old school hot rod guys told me a trick once upon a time about pulling the sensor and putting it in the freezer for 24 hours. Than tap it on some something to loosen the frozen sediment.
striktlyaccord pfffft.
« Reply #211 on: September 04, 2013, 06:47:58 AM »
^ Odd trick.
« Reply #212 on: September 04, 2013, 09:28:42 AM »
Its worked for me in the past. Not on the Accord but the old timers will surprise you
AccordEX
AccordEX pfffft.
« Reply #213 on: March 03, 2014, 11:34:05 AM »
Off topic, but I installed an intake and check engine light came on. Need help.Is it normal?
A man once told me... if ummm.... forgot.
« Reply #214 on: March 03, 2014, 01:55:07 PM »
A CEL is not normal. What is the code you're getting for the CEL?
« Reply #215 on: March 03, 2014, 02:32:39 PM »
May not have plugged in the MAF or its dirty. One of the two.
AccordEX
AccordEX pfffft.
« Reply #216 on: March 03, 2014, 04:21:44 PM »
Think it was 0171
« Last Edit: March 03, 2014, 06:24:35 PM by AccordEX » Logged
« Reply #217 on: March 03, 2014, 04:40:34 PM »
Find out exactly what the code is and I'll look it up in the service manual.
AccordEX
AccordEX pfffft.
« Reply #218 on: March 03, 2014, 06:58:01 PM »
Its 0171
« Reply #219 on: March 03, 2014, 11:36:57 PM »
P0171 - fuel supply system too lean
I'm betting that you have a vacuum leak somewhere.
AccordEX
AccordEX pfffft.
« Reply #220 on: March 04, 2014, 08:55:32 PM »
is it an easy fix or a pain in the ass?
« Reply #221 on: March 05, 2014, 08:25:58 AM »
Posts from the intake gasket thread moved here. That being said, finding a vacuum leak is fairly easy if you have the tools for it. In the driveway without said tools, you could be hunting for hours. Since I assume all you did was install an intake, I'd check to make sure you didn't split the silicon coupler at the throttle body as that can cause your code.
« Reply #222 on: March 06, 2014, 11:30:51 AM »
A can of carb cleaner can help you find a vacuum leak.  Just make sure you do it when your engine is cold.
AccordEX
AccordEX pfffft.
« Reply #223 on: April 06, 2014, 05:03:53 PM »
So I installed the stock intake and the cel didn't come back. After driving for 2 days I put the intake back on, boom cel is on. I'm thinking it's cause of a $50 intake? I've read that the light gives no problems, but it just disappointing seeing the light on.
« Reply #224 on: April 06, 2014, 10:07:25 PM »
Is it an intake or an intake manifold?
Pages: « First < Previous 1 ... 13 14 [15] 16 17 18 Next > Last »   Go Up
