September 28, 2026, 03:19:12 PM
Pages: « First < Previous 1 ... 16 17 [18]   Go Down
Author Topic: Check Engine Light Codes Discussion  (Read 175482 times)
« Reply #255 on: July 27, 2014, 10:19:14 PM »
great news
« Reply #256 on: July 27, 2014, 10:32:39 PM »
Sensor come out easy? Sometimes they suck!
theycallme_og
not that kind of OG
theycallme_og pfffft.
« Reply #257 on: July 29, 2014, 10:28:53 AM »
Bad news guys, well for me  Sad   On my way back home from work the Damn light came back on.  So once I got home I got my code reader and I am getting P0420. Cool
Looks like I am still going to have to buy a CAT..  So I guess I will start saving up for it.
« Reply #258 on: July 29, 2014, 10:41:17 AM »
Clear the code and see if it comes back.
« Reply #259 on: July 29, 2014, 10:41:39 AM »
There are a lot of things I'd try before buying the cat!
theycallme_og
not that kind of OG
« Reply #260 on: July 29, 2014, 11:37:32 AM »
I will clear it tonight.  But can you list the thing that i could do solve it.
I have already removed the CAT and left it over night in a bucket of soapy water TWICE.... and P0420 keeps coming back.
theycallme_og
not that kind of OG
« Reply #261 on: July 30, 2014, 11:18:32 AM »
So I was planning to clear the code when getting home, but just before arriving home from my 30 min commute the light went away.
Now its going back to its old habbits, it goes on an off when it chooses.
« Reply #262 on: July 30, 2014, 12:22:31 PM »
You should just monitor it and see what happens.
Which sensor did you replace again? The primary O2 (a/f) sensor before the cat, or the O2 sensor after the cat?
theycallme_og
not that kind of OG
« Reply #263 on: July 30, 2014, 01:54:16 PM »
After the CAT,  well the one that goes right in the middle of the CAT
http://ww2.justanswer.com/uploads/drivefast1971/2011-10-07_164736_1.gif
« Last Edit: July 30, 2014, 01:57:30 PM by theycallme_og » Logged
« Reply #264 on: July 30, 2014, 02:15:24 PM »
Okay. Just making sure. The P0141 code hasn't returned, but the P0420 has?
There are really only 2 options. Since you live in CA, one option may be considered illegal, but it's inexpensive. That would be to get one of those O2 sensor spacer/restrictors. If they do a visual inspection of your exhaust, then you probably won't get away with using one. The other option is a replacement cat. I believe Magnaflow sells one that's around $100-150.
« Reply #265 on: July 30, 2014, 09:03:23 PM »
the key to getting away with the spacer is to spray your exhaust black so it all matches. The shiny spot is always a dead give away.
theycallme_og
not that kind of OG
« Reply #266 on: August 04, 2014, 11:42:20 AM »
well its been a week and the light is still not coming back on..   so thanks for all the help guys
« Reply #267 on: August 04, 2014, 02:38:24 PM »
Glad it's working out for you.
Pages: « First < Previous 1 ... 16 17 [18]   Go Up
