November 07, 2026, 05:10:11 PM
brake fluid. i think this is real bad
Topic: brake fluid. i think this is real bad (Read 16024 times)
March 16, 2009, 11:19:32 PM »
well my clutch pedal acts wierd when shifint at high rpm, send pm to Paul already. just went outside to check fluid levels and they apear on normal level but looks like shit, dont know how it got that way holly shit.
here is pics
Re: brake fluid. i think this is real bad
March 17, 2009, 12:04:55 AM »
FLUSH IT OUT. Have you been flushing your brake fluid regularly. That is what usually happens when you don't flush it out.
March 17, 2009, 12:15:24 AM »
never done it. today im going to dealer to get brake fluid, changing on thursday
stirfriedferret
March 17, 2009, 03:12:03 AM »
also, use a pressure bleeder or manually bleed it. i learned the hard way by using a vacuum bleeder. no bueno.
Brian
SoCalCM Squad
EliteCM Profile
March 17, 2009, 06:02:03 AM »
I think im gona suck out as much as I can out of resevuar first and put new fluid there and then bleed it manualy. Is there way to bleed clutch lines?
March 17, 2009, 06:14:00 AM »
Yes, the clutch slave cylinder has a bleeder screw on it and you treat it just like the brakes as far as bleeding. To me it looks like moisture(water) is getting into the system, check you resevoiur caps.....
skizot
March 17, 2009, 06:35:07 AM »
They also make a do-it-yourself bleeder tool that you can connect to the bleeder screw on each caliper which pushes air bubbles and fluid up through the line into the reservoir. Something that is handy if trying to do this on your own. You could basically remove all the fluid, loosen up your bleeder screws and flush the system out yourself, tighten the screws, put new fluid in and then go one caliper at a time to bleed the air out of the system. Rather then having to pay the dealership to do it. I am sure we could all help you online do it yourself, but if you don't feel comfortable, then you should take it somewhere for someone who does.
March 17, 2009, 07:26:08 AM »
im gona do it at my friends garage so i can do it there, maybe he has something like that since he is auto tech
March 17, 2009, 07:44:00 AM »
Talked to Paul and gona flush my brake/clutch on thursday
March 17, 2009, 12:02:12 PM »
Sounds like a good idea. I need to do the exact same thing myself. I'm probably doing it this weekend when we install Keith's exhaust.
rjp6262
March 19, 2009, 12:22:27 PM »
mine looked exactly like that when i got mine flushed. glad i did, but i still have a hard spot in the brakes right when i press the pedal in...any ideas?
March 19, 2009, 01:29:05 PM »
do you know how many bottles of brake fluid you needed?
March 19, 2009, 02:29:39 PM »
got 4 bottles of honda brake fluid for free, hope i can change before next week, probably tomorrow
suleman_manji
March 19, 2009, 10:24:35 PM »
Quote from: "stirfriedferret"
that's if you don't use it right/get the cheap ones. vacuum bleeders are the shit.
T
X
Squad #
flick
r
fb
[img]http:
March 19, 2009, 10:27:35 PM »
bled the brakes and clutch. my friend had vacuume tool for that.
but my clutch still has the same problem. i dont get it, wtf
