June 18, 2026, 06:25:31 AM
[Profile] Pascal
12
Topic: [Profile] Pascal (Read 142795 times)
Pascal
Re: [Profile] Pascal
Reply #105 on:
December 19, 2014, 05:24:09 PM »
Began to take appart my k24a4, it is in worst condition than I thought, I'll have quite a lot of work to do to rebuild it !
Reply #106 on:
December 19, 2014, 09:01:35 PM »
What are you planning on doing with it? A K24A1 head swap would be a good upgrade.
Pascal
Reply #107 on:
December 19, 2014, 10:00:53 PM »
This engine will not go back into the car (well it's not planned to). I plan to use it as my test dummy. This is my first engine rebuilt and I think this is the perfect engine to learn how to do it. If it is successful, well I probably can sell it as a k24a4 replacement engine and maybe I can do a bit of money on it. On the other hand, if something goes wrong, the engine in pieces is worth more (the base is often used for k24/k20 Frank) than as a complete one, so its not a big deal if I mess something up.
I want to do a stock rebuild for now, if during dismantle I see a major part that need replacement I might consider other options.
I'm still not sure whether use oem parts for gasket and stuff or go cheaper with other brands (open to suggestions on cheap but still good quality parts). I don't really want to put 1000$ on new honda parts to sell the engine 800$
Reply #108 on:
December 20, 2014, 02:03:43 PM »
Go with OEM gaskets and bearings.
Pascal
Reply #109 on:
December 20, 2014, 03:47:59 PM »
How much could I sell it afterward if it is all in top shape with oem parts ?
Reply #110 on:
December 20, 2014, 05:56:32 PM »
Ehh. If you're rebuilding it just to sell it, you probably won't make much from it or even get your money out of it.
Pascal
Reply #111 on:
January 01, 2015, 04:24:10 PM »
More car parts
Reply #112 on:
January 02, 2015, 08:58:41 AM »
Still planning on doing the MT swap in the future?
Pascal
Reply #113 on:
January 02, 2015, 11:39:30 AM »
Yup! Don't know when, but when the time will be right, I'll be ready.
Only need clutch master, pedals, and shifter box (this one is broken on one of the bolt holes)
there might be other stuff I forgot I would need but I think this is it
Reply #114 on:
January 02, 2015, 10:05:06 PM »
Where's your list, do you have manual gauge cluster, clutch fluid reservoir, IM if different? Just a thought.
Reply #115 on:
January 03, 2015, 01:06:13 AM »
If you need a shift box, I still have a few lying around. I would recommend picking up an EM1 clutch master cylinder. It isn't plagued with the problems that the newer ones have.
Pascal
Reply #116 on:
January 03, 2015, 11:09:54 PM »
Quote from: Rich01 on January 02, 2015, 10:05:06 PM
Haven't done a list yet, I'll probably keep my auto cluster ( still works, there will be non-working PRND lights but who cares), The reservoir was included in my mind when I said clutch master. I have a TSX IM from a MT donor and it works so I guess that's no problem there.
Quote from: timot_one on January 03, 2015, 01:06:13 AM
I'll let you know for the shifter box when I'll be closer of doing the conversion if I still need one. Thanks for the tip about the master cylinder. Is it a direct fit ? bolt pattern, connection to the pedal and stuff ?
Reply #117 on:
January 04, 2015, 02:24:18 AM »
Yes. The clutch master cylinder is a direct fit. It's what I use on my car. In the past, I have destroyed clutch master cylinders. I haven't had any issues with this one. I put 6000 miles on it with a Competition Stage 4 and now use it with my Competition Twin Disc.
Pascal
Reply #118 on:
January 04, 2015, 09:29:32 PM »
Thanks !
Pascal
Reply #119 on:
January 15, 2015, 03:51:53 PM »
Got a few things today
Local guy crashed his red sedan
new oem trunk lip
asian style grille (minor scratches on it)
new roof lip (not sure i'll keep it)
2 months old Skunk2 camber kit (only if my alignment is not acceptable after lowering) and moog link kit.
12
