November 07, 2026, 08:26:05 PM
Pages: « First < Previous 1 2 [3] 4 5 6 Next > Last »   Go Down
Author Topic: Suspension clunk from front PS - case closed?  (Read 93701 times)
Reputation Power: 10
NVA-AV6 pfffft.
« Reply #30 on: March 27, 2013, 08:08:16 AM »
Are you absolutely sure your upper control arm is not making contact with the bottom of the strut tower? Also same for the lower control arm in the subframe? I can see with you being fairly lowered reaching the limits for the suspension design, I actually had a customer who was soooooo low the locking nut in his ingalls camber kit busted thru the metal in the strut tower.........
« Reply #31 on: March 27, 2013, 08:13:33 AM »
Absolutely certain. If that were the case, the DS would be doing it as well. My drop is about 2.5" (right at the tread). Like I said before, this didn't start until my drive north from Miami. My ride height hasn't changed since before I moved. The only thing that did change, besides the recent parts changing, were my wheels from something aggressive to a set that is considerably less aggressive.
NVA-AV6 pfffft.
« Reply #32 on: March 27, 2013, 12:01:38 PM »
Have you checked the mid subframe mount? it is the one near the axel and is held in with 2 14mm head bolts to the subframe and 1 17mm head bolt5 to the chassis.
« Reply #33 on: March 27, 2013, 12:14:39 PM »
I gave it a look over but not a thorough check. I'm going to throw her on the jack this afternoon and check that out.
« Reply #34 on: March 27, 2013, 01:22:26 PM »
Is #11 the one you're talking about Paul? P/N - 50280-SDA-A01
« Reply #35 on: March 27, 2013, 02:03:08 PM »
Yes, he means #11/12 in the picture.
« Reply #36 on: March 27, 2013, 02:17:15 PM »
That's what I figured but needed to confirm. That little mount looks so unassuming and I can't imagine it being the problem. I guess I'll find out later this afternoon if the sky doesn't fall on me.
NVA-AV6 pfffft.
« Reply #37 on: March 27, 2013, 03:25:50 PM »
I'm just trying to think of "non-common" parts that could be making the noise described.
NVA-AV6 pfffft.
« Reply #38 on: March 27, 2013, 03:27:22 PM »
I'd also look at 22,23 as well as the rubber mount for the down pipe.
« Reply #39 on: March 27, 2013, 03:48:06 PM »
Funny you mention 22 and 23. I actually did pop those two off and had a look at them as they are pretty odd looking parts. No broken rubber or anything physically wrong with them.
« Reply #40 on: March 28, 2013, 12:43:27 AM »
Those are weights to reduce vibration.  Mine have been long gone for a while now.  You can remove them if you want, but you may get more engine vibration if you do.
« Reply #41 on: March 28, 2013, 08:22:19 AM »
That's what they looked like to me and didn't look like they served much of a purpose IMO. I threw them back on since they were already there and not disturbing anything. Later on down the road, I may just take them off for that JDM weight reduction.
« Reply #42 on: March 28, 2013, 09:54:59 AM »
More weight reduction than taking a dump.
« Reply #43 on: March 28, 2013, 10:36:20 AM »
Damn right! And I take a dump on the regular!
« Reply #44 on: March 28, 2013, 06:47:10 PM »
Just pulled that mount. No dice. Damn thing is fine.
Pages: « First < Previous 1 2 [3] 4 5 6 Next > Last »   Go Up
