November 09, 2026, 07:15:25 PM
function and form coils Clunking noise ?????
Topic: function and form coils Clunking noise ????? (Read 26450 times)
paulonfiya
January 29, 2012, 02:41:22 AM »
I just installed the coilovers 2 months and the suspensions are making a clunking noise like the coilovers are blown and bottoming out but the ride is not bouncy. I haven't touched the preload at all. And I'm not even dropped that much.
| SOS | Inspire Fog Light | FF1 | Weds Sport | JL Audio | Focal Audio | Memphis Audio | Infinity Kapa |
paulonfiya
Re: function and form coils Clunking noise ?????
January 29, 2012, 02:51:59 AM »
helppppppppppp
January 29, 2012, 09:01:34 AM »
Quote from: paulonfiya on January 29, 2012, 02:51:59 AM
helppppppppppp
When you're posting that late at night, you really shouldn't expect to get a response in less than 10 minutes. Be patient and people will try and help. It's also a good idea to try and provide as much information as possible.
Where is the noise coming from? Front, rear, all four corners? What have you checked since you started hearing the noise?
Last Edit: January 29, 2012, 09:13:16 AM by timot_one
January 30, 2012, 01:14:01 AM »
your front ball joint is hiting in the inside.. mines does it all the time when i hit a hard bump.
January 30, 2012, 09:52:12 AM »
Quote from: paulonfiya on January 29, 2012, 02:41:22 AM
Alex, that only happens when you're dumped or have the Ingalls front camber kit. From the pictures he's posted of his car, it doesn't seem that he's so low that it would cause his upper front ball joint to hit the shock tower. Anyway, he was vague about the details, so it's hard to assume what the problem is. It could be as simple as a nut that wasn't torqued properly and worked itself loose.
paulonfiya
January 31, 2012, 11:01:44 PM »
noise coming from rear passgr side..
DIY: Megan Racing Coilover Noise Fix 1
i have same problem but its coming from rear pass, but middle bolt tight
January 31, 2012, 11:34:01 PM »
So wait, is yours moving like the one in the video? Can you tell us what you've done so far to try and resolve this?
paulonfiya
February 04, 2012, 08:38:21 AM »
yea on rear passenger side, i havent fixx it yet, i tried to tightning up but it was tight already. next plan to take off then re install it.....
February 04, 2012, 11:08:53 AM »
That's your best bet. Take it out, make sure the top hat is tight and then reinstall. It may turn out that you may find some damage.
paulonfiya
February 05, 2012, 01:34:51 AM »
yea
February 05, 2012, 09:37:27 AM »
Let us know how it turns out Paul. I'm interested to find out what the problem was.
paulonfiya
February 06, 2012, 11:13:38 PM »
ok
February 17, 2012, 01:01:40 PM »
Not sure if this helps, but others are having similar problems with the HT-Spec Type coils (i.e. custom F&F):
New F&F Coilovers Sound Blown??
paulonfiya
February 21, 2012, 12:42:36 AM »
its not blown the main nuts from the tophat is lil lose
February 21, 2012, 08:33:47 PM »
Glad it was a simple fix.
