September 29, 2026, 12:17:04 AM
Audio Systems
Amplifier Fan?
Topic: Amplifier Fan? (Read 16943 times)
Amplifier Fan?
October 19, 2011, 03:01:58 PM »
I've noticed that my Amp overheats and shuts off if I listen to my stereo for longer than an hour. It doesn't matter if it is 90 degrees outside or 40 degrees, it almost always overheats.
Normally this doesn't really matter since I usually don't drive longer than that but I have a couple long-distance car trips planned and I don't want my stereo crapping out before I get there.
So I was looking into cooling options and came across
http://www.hifisoundconnection.com/Shop/Control/Product/fp/vpid/1331967/vpcsid/0/SFV/30046
Not sure if it is any good or if there are better options out there. Any thoughts? Also, what would be the best way to wire it up? Wiring electronics isn't my forte.
Thanks!
Re: Amplifier Fan?
October 19, 2011, 04:56:55 PM »
how is the amp mounted?
Re: Re: Amplifier Fan?
October 19, 2011, 06:40:44 PM »
Better question would be, how is the amp wired?
Re: Amplifier Fan?
October 20, 2011, 07:46:36 AM »
The amp is mounted on carpeted particle board on the back of the rear seat along with my capacitor and RF 3sixty.1.
As for how it is wired, I'm not really sure since I had an audio shop hook everything up for me. As I said, I'm not very good with wiring.
I do know it's a 5-channel amp and is amping all 4 speakers and my sub.
Re: Amplifier Fan?
October 20, 2011, 08:31:47 AM »
October 20, 2011, 09:44:16 AM »
Last time I had an amp overheat on me was when the amp wasn't wired correctly. For example, you wire up 4 ohm speakers to an amp that only works at 2 ohms which causes an impedance mismatch. Without knowing EXACTLY how your system is wired, its difficult to troubleshoot over the intarwebz.
Re: Amplifier Fan?
October 20, 2011, 10:34:05 AM »
+1 to the wiring setup and also take into account that your amp is pushing your interior speakers as well ass your subs... (over working it?) A fan would'nt actually be bad. Especially if that subs pump from the bass the amp is being worked to it's RMS output wherever you have it leveled to.
...I was thinking about doing this when I installed by amp but I got through the hot months with no problems so I 86'd that idea
Re: Amplifier Fan?
October 21, 2011, 12:05:50 AM »
Wait a minute. I swear I fucking posted in here. David and Z are both right. Check the amp's owners manual to make sure it's mounted properly. That position could cause it to overheat depending on the amp you're using. Wiring can also cause it based on what Z posted, which is pretty much the same thing that I said in my missing post.
Re: Amplifier Fan?
October 21, 2011, 07:46:09 AM »
I'll take a look at it this weekend and see if I can make heads or tails of the wiring. Thanks
Re: Amplifier Fan?
October 21, 2011, 08:25:49 AM »
I found this in the manual about mounting:
Mounting: Choose a structurally sound location to mount your Kicker amplifier. The controls on the
top of the amplifier need to be accessible for adjustment. Make sure there are no items behind the area
where the screws will be driven. Choose a location that allows at least 4” (10cm) of open ventilation for
the amplifier. If possible, mount the amplifier in the climate-controlled passenger compartment. Drill four
holes using a 7/64” (3mm) bit and use the supplied #8 screws to mount the amplifier.
Doesn't say anything about not mounting it vertically so I think I'm good there.
http://www.kicker.com/sites/default/files/2006%20ZX%20550-3%20700-5%20Multilingual%20a01.pdf
Last Edit: October 21, 2011, 08:27:49 AM by ikethegreat
Re: Amplifier Fan?
October 27, 2011, 01:41:18 PM »
Ok guys I'm confused. I mounted the fan and tried wiring it to my amp. I connected the ground wire to the amp's ground connector and the power wire to the amps power connector. The fan started running even with the car/amp turned off. I moved the power wire to the Remote Turn On connector and it still ran even with the car/amp off. What am I doing wrong? Is it because I have a cap?
Re: Amplifier Fan?
October 27, 2011, 11:25:16 PM »
Actually, you shouldn't wire it to the amp in either configuration. You really should be using a relay. You would run ground to the fan ground 85, the remote trigger to 86, 12v power to 87, and fan power to 30. Make sense?
Re: Amplifier Fan?
October 28, 2011, 08:14:57 AM »
If I understand you correctly, this is how it should be wired up right?
Re: Amplifier Fan?
October 28, 2011, 08:44:04 AM »
Very close. Terminal 85 also needs to be grounded to the chassis, or you could run it to the amplifier ground.
Re: Amplifier Fan?
October 28, 2011, 01:23:42 PM »
So terminal 85 and the negative wire on the fan can both be ran to the amp ground?
Thanks for your help Tim
