March 07, 2026, 07:30:47 AM
Author Topic: End Links  (Read 33976 times)
Asim pfffft.
« on: September 12, 2011, 01:18:49 PM »
Hello!
I have the TL-S Front and rear sway bars, I need new endlinks...
Options
OEM Honda Accord
OEM Acura TL-S
Moog replacement
Other?
TL-S front sway bar holes are larger than OEM Accord endlink, so it could have some play... Using the TL-S end links solves the potential problem however requires the arm's hole to be drilled out a little
What is my best solution/option? Price is not a major issue unless we're talking huge price jumps between options
« Reply #1 on: September 12, 2011, 07:24:56 PM »
Use Moog parts. They are of great quality and are usually grease able.
Rushzer0 pfffft.
« Reply #2 on: September 13, 2011, 08:37:56 AM »
^ +1 And usually lifetime warranty on them as well
« Reply #3 on: September 13, 2011, 09:28:06 AM »
I have Moog on my car.  The only other thing you might want to consider is an aftermarket adjustable end link.  The only thing is that I doubt you need to adjust the preload on your sway bar.
« Reply #4 on: September 13, 2011, 09:35:57 AM »
I can get you said moog parts for 20% off + shipping of course.
Asim pfffft.
« Reply #5 on: September 14, 2011, 10:40:03 AM »
Yup Adjustable is not something I need!
Moog sounds good... I'll PM you when I am ready to buy Mike
Are there other things I should look at "while im at it"? I am planning on doing as much long term maintenance for my car as i can at this point...  (not limited to suspension)
« Reply #6 on: September 14, 2011, 03:16:07 PM »
Which end links are you looking for so that I can get you my pricing.
Asim pfffft.
« Reply #7 on: September 27, 2011, 08:39:28 PM »
Moog End links part numbers:
K90660
K90661
K90343
K90342
Should I just get all of my major suspension components checked out?
« Reply #8 on: September 27, 2011, 09:03:15 PM »
Not a bad idea... Let me know when your ready I'll get you some prices.
Asim pfffft.
« Reply #9 on: November 13, 2011, 08:06:15 PM »
Please PM some prices.. Thanks
Asim pfffft.
« Reply #10 on: November 17, 2011, 12:30:09 PM »
Thanks for the pricing!
Is there some stuff on the car I should just replace anyways since I am getting to this point in my car's maintenance (almost 150000km).
Ie like Motor mounts, spark plugs, bushings?? I am trying to keep my car running tight as I still want it to last another 2 years at a minimum..
Asim pfffft.
« Reply #11 on: March 23, 2012, 08:22:33 PM »
bump for the long term maintenance question!
« Reply #12 on: March 23, 2012, 08:53:29 PM »
Spark plugs should be changed. Motor mounts and bushing only if they are worn and or failing.
Silver Bullet
Silver Bullet pfffft.
« Reply #13 on: June 29, 2012, 04:35:45 PM »
Bump
I'm looking into getting the TL-S front rsb and I was reading up on the first 4 pages of the TL-S sway bar thread on v6p and noone mentioned drilling holes for the front. Have you installed the front sway bar yet OP? And did you use the moog end links for the TL-S for the front or did you get the moog end links for the accord for the front sway bar?
2006 AV6 6MT
« Reply #14 on: June 29, 2012, 04:42:38 PM »
If you use the TL-S front sway yes you need to drill your control arms which will work with the tl-s moog end links , accord end links only if you choose to get the regular tl front sway bar
