November 07, 2026, 06:26:13 PM
Author Topic: TSX Parts on 04 Accord?  (Read 11259 times)
korrupt3dazn
korrupt3dazn pfffft.
« on: May 25, 2011, 03:10:02 AM »
I know for TSX IM
i4 Accord 03-05 You need 04-05 TSX IM
i4 Accord 06-07 You need 06-08 TSX IM
I assume I would need the TB and Headers off an 04-05 TSX since I have an o4 accord? Or does that only matter for the Intake Manifold?
« Reply #1 on: May 25, 2011, 05:06:31 AM »
All you need is the IM. FYI, we have 4 bangers. Its a header.
korrupt3dazn
« Reply #2 on: May 25, 2011, 09:32:01 AM »
I already have the 04-05 TSX IM installed. I was just wondering for Exhaust header and TB do I have to get it from the 04-05 TSX? or can I get it from any year (04-08)
« Reply #3 on: May 25, 2011, 10:31:05 AM »
Doesn't matter. The TSX header is longer than any header made for our cars. You'd have to mod the exhaust for it to bolt on properly. Also, the TB's are identical if you plan on going stock for stock.
korrupt3dazn
« Reply #4 on: May 25, 2011, 10:35:55 AM »
yea I am aware of the 2" that need to be cut off the exhaust. I just wanted to make sure it would bolt up to the engine. i was just wondering because for intake manifold I need it off a 04-05 tsx, would I need the exhaust manifold off the accord from 04-05 tsx as well?
« Reply #5 on: May 25, 2011, 11:13:33 PM »
The TSX exhaust manifold isn't really worth spending money on.  Go with aftermarket instead.  I have both, if you want to buy one.  The TSX TB is not the same as the 04 Accord.  You cannot use a TSX TB on an 03-05 Accord.
The 04 Accord TB is DBC (cable).
All TSX TB's are DBW (not cable).
« Reply #6 on: May 27, 2011, 01:52:32 AM »
I was under the impression the TB's were the same. I totally forgot the TSX TB was DBW.
Asim pfffft.
« Reply #7 on: December 02, 2011, 12:58:46 PM »
Does that mean the TSX TB would work with 06-07 (DBW) i4's?
Is the TSX TB larger diameter?
« Reply #8 on: December 02, 2011, 10:49:16 PM »
If you can use a TSX IM on an Accord (with the Accord TB), then there's no reason why you can't use a TSX TB.  I'm not sure if the bore is the same size though.  If it is, you'd probably want to port match the IM to the TB.  I doubt you'd see much gains from it though.
« Reply #9 on: December 03, 2011, 10:41:16 AM »
I could've sworn the two were the same bore size. I think I remember reading that on k20. Not sure though.
korrupt3dazn
« Reply #10 on: December 06, 2011, 04:14:10 PM »
Got bored at work and was searching for awhile and looks like the k24a4 (03-05 accord) and k24a8 (06-07 accord) has a TB diameter of 60mm. and TSX 06-08 TB has a TB Diameter of 64mm. So I guess if you had 06-07 accord and you get the TSX IM you should get the TSX TB as well...
