October 06, 2025, 10:42:34 AM
Author Topic: Question about HID's  (Read 9424 times)
« on: January 04, 2011, 09:43:57 AM »
Why is it that cars like the second generation TL and the Subaru STI come from the factory with stock HID's with no projectors and an accurate cut-off on the lights?  Is it because of the interior reflector design?
CYANiDE pfffft.
« Reply #1 on: January 04, 2011, 11:08:50 AM »
Yes sir.
There are some cars that have their reflectors designed to work with HIDs.
« Reply #2 on: January 04, 2011, 12:00:17 PM »
I'm with Stupid
Those cars also use D2R bulbs which are HID bulbs used in reflector housings as opposed to D2S bulbs used in projectors like mine.
HIDPlanet is your friend!
« Reply #3 on: January 06, 2011, 08:20:40 AM »
It has to do with the design of the reflector housing.  The Inspire headlights are reflector based HID housings and they use a D2S.
k24low20z pfffft.
« Reply #4 on: January 06, 2011, 11:10:20 AM »
Yes, like tim and z are sayin.. Those reflector housings were made to house hid bulbs not like other halogen head lights that are made to only use halogens in them, so when you use hid on them you get too much glare because the bulb is not  for that type of reflector.. Best way to do it is save some $$$ for a kick ass retro..
« Reply #5 on: January 06, 2011, 05:18:46 PM »
Guess it's best if I save up for those inspires then, huh.
« Reply #6 on: January 06, 2011, 10:20:14 PM »
That's what I did. Wink
« Reply #7 on: January 07, 2011, 06:47:27 AM »
From what I understand, those don't have all that great an output. They are also for RHD vehicles so the cutoff is wrong. Sure, they look sexy but that's about it.
« Reply #8 on: January 07, 2011, 08:25:53 AM »
I understood that they can be adjusted for left or right, am I wrong?
« Reply #9 on: January 07, 2011, 08:29:43 AM »
Z Bag is right.  The output of reflector based HID's doesn't compare to the output of projector based HID's.  The flare being opposite to a LHD vehicle is something that most people have reported not being a problem.  They cannot be "adjusted" as you were told Nelson.  Whoever told you that is a motherfucking moron.  There is a guy from back in the day that modified his Inspires so the cutoff was flat.  If you're okay with opening up your $700 headlights and taking a dremel to them, then it's not a big deal to do.
There hasn't been anybody that has retrofitted them yet, but I think a smaller projector may fit in the high beam reflector.
By the way, they do look sexy as hell in person.  Especially at night.  Fashion over function!!   Wink
« Last Edit: January 07, 2011, 08:32:17 AM by timot_one » Logged
« Reply #10 on: January 07, 2011, 10:02:49 AM »
Thank you Tim.
Edit:  Even though Inspire's are not as effective as projectors, they're still better than just popping in HID's inside of our OEM headlights, correct?  So, I take it, it's like the middle ground.
« Last Edit: January 07, 2011, 10:15:34 AM by gargantula99 » Logged
« Reply #11 on: January 07, 2011, 10:42:18 AM »
Its more than a middle ground...
For asthetics its the best option, and for output its improved over stock.
« Reply #12 on: January 09, 2011, 02:27:57 AM »
I'm still not a fan of popping headlights from a RHD vehicle onto a LHD vehicle due to the cutoff being wrong and the customary flare going into the wrong direction, blinding oncoming drivers in the process just like PnP HIDs in our halogen reflectors. If I could afford it, I'd pick up a set of Inspires, retro a set of S2K projectors in the low beam with a vacuum form shroud and leave the high beam alone.
Fashion AND function bitches! Booyah!
« Reply #13 on: January 09, 2011, 09:53:01 AM »
I disagree with you. Having read alot about both setups if aimed slightly low I don't think that the cut off is an issue.
Reputation Power: 18
alpha pfffft.
« Reply #14 on: January 09, 2011, 03:04:55 PM »
werd.  After I adjusted my Inspires, the lighting output was fantastic.  It looked great, and people didn't really high beam me after I aimed the left side slightly lower.  Granted the cutoff did flare left, but it wasn't too bad.
