September 20, 2026, 11:00:58 AM
Bolt Ons
throttle body
Topic: throttle body (Read 14569 times)
JRv6
throttle body
May 27, 2010, 04:56:36 PM »
hey guys i'm having a problem with my TB... According to the computer it gave me the codes that the TB is messed up so did a bit a research n the dealer is the only place for me to buy the TB but they want $400.18... So i'm like if i'm going to spend $400 on a stock TB I rather spend the $$ on an aftermarket TB, so does anybody know where can I get a performance TB or any other suggestion on what should I do... With the TB any suggestion will b greatly apreciated. Thank you!!
Re: throttle body
May 27, 2010, 07:01:27 PM »
Time to hit the junkyard. What code did you pull? No one makes an aftermarket TB for the J30A4 yet. You can have Paul (NVA-AV6) make a Big Mouth TB and IM for you. Totally up to you on that one.
Re: throttle body
May 27, 2010, 07:27:20 PM »
Go with the big mouthed TB from Paul. I currently have the IM spacer and that will be a part of my next purchase from him. Like Thien said though, it's up to you. Junk yard or ebay may be an option also.
Re: throttle body
May 27, 2010, 10:14:58 PM »
I'd also like to know what code you got.
Re: throttle body
May 28, 2010, 05:48:12 AM »
I also would want to know what code you got, but anyway, check the link below, $280 for a new TB....
http://www.bkhondaparts.com/billkay/jsp ... =&hidIrno=
JRv6
Re: throttle body
May 28, 2010, 07:59:19 PM »
thanx 4 the info peeps... Ebay been looking n can't find one n junkyard it's kinda hard to find the v6 out here in SW Florida... On the code I will have to get back to you on that... Engine light still there I kinda stop driving ma car cuz when I take it out eventually the engine will start hesitating n when getting ma foot of the pedal the car jerks aggressively... And when that happens n I come to a full stop the car just won't go... I have to turn the engine off n start again to reset the whole thing... Anyways b4 I purchace anything I want to make sure... I will get back to you guys wit the code n with ur advice i'll make the next step...
Re: throttle body
May 28, 2010, 09:43:20 PM »
did you take it out and see maybe you need to clean it? maybe something got into it?
Re: throttle body
May 28, 2010, 11:05:05 PM »
You can also look at car-part.com for used parts. That code is key though. We really can't help you until you tell us what it is.
Re: throttle body
May 28, 2010, 11:44:42 PM »
Quote from: "JRv6"
sorry I can't help, having a really hard time understanding your English...
get the big ass TB and IM from Paul, that is on my list of things to get!
JRv6
Re: throttle body
May 29, 2010, 05:56:25 PM »
lol no problem... Uh... Yeah I took the TB out, cleaned it, I also cleaned the CAI filter and the pipe... It kinda helped the 1st day but then it started doing the same thing... I was gonna get the error code 2day but i'm still @ work but hopefully by the end of the day or 2morrow i'll borrow the scanner to get the code...
JRv6
Re: throttle body
May 29, 2010, 08:03:58 PM »
ok guys I finally have the error code... P2138 Throttle/Pedal Position Sens/Sw D/E Volt Correlation... I'm open to suggestions, ideas... Thanks for the help!!
Re: throttle body
May 29, 2010, 08:12:24 PM »
Change out the sensor first. Clear the code and see if it comes back on. The sensor is located right behind the strut tower bar on the right side. If the code comes back on, then replace the throttle body and hope that solves your problem.
JRv6
Re: throttle body
May 29, 2010, 08:28:18 PM »
that's a big 10-4... I will jump on it n see what it does... I'll keep you updated!!
Re: throttle body
May 30, 2010, 10:29:07 AM »
WOW, I was actaully able to read what you said!
good luck on figuring out the problem!
JRv6
Re: throttle body
May 30, 2010, 03:50:27 PM »
lmao!! I get you... I make no sense sometimes, I don't even understand my self sometimes lol it's all good tho... I just need to remember we not texting here lol... Oh well i'll replace that sensor but it won't happen until Tuesday... Since tomorrow everything is going to be closed so hopefully that will solve the problem...
