January 28, 2026, 05:59:48 PM
Audio Systems
Simple sub build.
Topic: Simple sub build. (Read 7527 times)
Simple sub build.
February 20, 2009, 11:31:04 AM »
I'm sure folks have discussed this before on the old site...but nothing here yet.
Overall, I am pretty impressed with the OEM sound system in the EX version of our cars. I do listen to a lot of bass heavy music...and am thinking about getting a little more low end punch. In my previous car I had a 15" hooked up to a 200W RMS amp...and it was big and heavy, took up my whole damn trunk....and at full blast it was enough to give you vertigo. Anyone have some recommendations on a small, light, simple way to get a little more bass in my car?
thanks
RTexasF
Re: Simple sub build.
February 20, 2009, 09:30:34 PM »
Bazooka 10" 200 watt
Infinity Basslink
I 've had the Bazooka and it takes a little while to break in then it fills in the bass wonderfully. Not heard a negative comment on the Basslink either. If you are looking for solid bass to accent a current system these will work very well. If you want to piss off the neighbors neither will fill the bill.
Rick, token old bastard.
mnkyman
February 20, 2009, 10:31:29 PM »
Do you have a JL cleansweep on your set-up Rick?
Sam
-|- 2006 I4 Sedan SE
February 20, 2009, 11:48:40 PM »
One idea is to get a single 10" sub with a custom enclosure. You could also get 2 8"s. Are you trying to save space, or do you just want a little more bass without worrying about losing trunk space? What is your price range?
February 21, 2009, 01:29:47 AM »
I'd like to keep as much trunk space as possible. I drive cross-country about twice a year and I am amazed how much crap I end up taking with me. I'm on a budget...I don't need anything high-end...just something to give the low frequencies a little more authority and take some strain off the oem speakers. The oem 6x9's are not that bad...they just distort at higher volume...I don't listen to anything that loud...around 15-16 on the volume dial is average for me.
I'm wondering if a 10" would really be able to produce bass much better than a 6x9....perhaps the 10's I've heard before were just junk. I was sort of thinking a 12".
Sworkhard
February 21, 2009, 07:16:50 PM »
one decent 10 would produce much better and more bass if put into a properly designed enclosure than any pair of 6x9's because the 10" sub is in an enclosure, while 6x9 are free air speakers designed to be put into your rear deck.
[size=150]Stephen[/size]
03 Accord EX-L 5MT
February 22, 2009, 12:47:25 AM »
6x9's aren't much to talk about. One 10" subwoofer will produce more bass because it's a subwoofer. The 6x9's are basically midwoofers that also reproduce high frequencies. As Sworkhard said, a decent 10" subwoofer
in a properly designed enclosure
will give you ample bass if you are just looking for a little more kick without compromising as much space.
