July 28, 2026, 02:25:10 PM
Brakes
Brake squeal solution help
Topic: Brake squeal solution help (Read 12723 times)
April 11, 2010, 10:48:54 PM »
Been running my front Brembro blanks with Hawk HPS pads setup for over 2 1/2 years and have had pretty persistent break squeal, but it doesn't happen when I brake lightly or heavily, only
moderately
. I had my mechanic cake some messy red anti-squeal goo behind the pads before the winter rolled in, and it helped for like 2 months before the noise came back again. Anyone have any recommendations on another tactic to use? My mechanic suggested that the "metal parts" on the calipers that the pads slide into can eventually wear down and cause rubbing and squealing, but I know nothing about this. Maybe order new "metal parts" (can't remember the official name... shims?), or just blame it on it being an afermarket, noisy setup? Help.
--Dave--
NECM Squad
Profile & Mods List
2003 I4 Accord Sedan
Re: Brake squeal solution help
April 11, 2010, 11:28:59 PM »
I blame it on the Hawk pads. I have the saem setup, and I get the occasional squeek. I blame it to the Hawk pads emitting off a lot of brake dust. First, I would put anti seize behind the pads. Second, I would lube the slide pins. I plan on resurfacing my rotors and deburring my pads to maybe help with the squeek. If all else fails, I'm getting new pads. I hate the squeek, and it annoys the crap out of me. The hardware itself will not cause your brakes to squeek. They are there to help the brake pads slide, and to keep it stationary.
April 12, 2010, 08:16:25 AM »
+1 on the Hawk pads. I had the same squeal with my Hawk pads.
April 12, 2010, 09:44:26 AM »
I've been running the hawk pads front and rear for a year + and don't have this issue at all.
April 12, 2010, 10:00:39 PM »
So it might possibly just be the composition of the pads... greeatttt.
Quote from: "MyNameIsThien"
Thanks for the tips Thien. So do you mean put more of the anti-squeal behind the pads (exactly what my mechanic did but it only helped for two months), or actual grey anti-seize that you'd typically use for bolt threads and stuff? I might need to have my rotors rotated or resurfaced as well, as I'm getting some shudder again. How do you "debur" pads exactly?
--Dave--
NECM Squad
Profile & Mods List
April 12, 2010, 10:41:28 PM »
Quote from: "striktlyaccord"
I usually put the grey anti "seize". It works great, and I use it on all the cars I work on. I rarely have comebacks when doing that. If you are getting a shudder, I highly suggest resurfacing them if there is room to resurface. As for deburring the pads, I usually just use the flat part of a concrete floor and just put a little force and rub the pad back and forth.
April 12, 2010, 11:05:27 PM »
I have used that red shit that is for brakes, it has worked since I did my GS caliper and Coupe bracket/rotor upgrade, which is like 6+ months now. they just started to sqweek (htf do you spell that?!) again. I am going to him them with some brake cleaner and re-apply the red schtuff.
Thien, any particular brand anti-sieze?
April 12, 2010, 11:08:29 PM »
No particular brand. All anti seize are the same.
April 13, 2010, 08:52:59 PM »
Thanks for all the info Thien. I shouldn't have a problem resurfacing the rotors if they really need it since they've never been resurfaced before.
--Dave--
NECM Squad
Profile & Mods List
April 13, 2010, 08:56:25 PM »
I think pepboys does it for 10-15 $
April 15, 2010, 12:42:52 PM »
Pep Boys... "does everything for less" lol.
--Dave--
NECM Squad
Profile & Mods List
April 24, 2010, 06:36:25 PM »
When I cleaned up my brakes and wheel wells last week, I used some brake cleaner on the brake components, and the squeal stopped for like... 15 miles, then came back. Joy.
--Dave--
NECM Squad
Profile & Mods List
April 24, 2010, 08:24:29 PM »
Did you use brake cleaner on the rotors and pads? If so, thats why. Do not use brake cleaner on rotors or pads.
April 24, 2010, 10:47:44 PM »
That's so confusing.
April 24, 2010, 11:11:17 PM »
yeah, why not Thien? I was going to do that this weekend...
