January 31, 2026, 05:25:15 AM
Author Topic: Brake squeal solution help  (Read 11505 times)
striktlyaccord pfffft.
« Reply #15 on: April 25, 2010, 10:50:51 AM »
Yeh, wth?  If you can't use brake cleaner on rotors and stuff, than what CAN you use it on??  I didn't even let the stuff dry; everything got washed with soap and water at the same time.
« Reply #16 on: April 25, 2010, 07:35:13 PM »
You are suppose to use hot soapy water to clean rotors. You can use brake cleaner on new rotors to get the oil film off. Afterwards, you are suppose to use hot soapy water. Brake cleaner evaporates very quickly and what it does is magentize metal particles together. This will cause rotors to squeek from time to time.
« Reply #17 on: April 28, 2010, 01:18:05 AM »
Quote from: "MyNameIsThien"
Interesting.  My rotors have squeaked well before ever using brake cleaner on them, however.  I guess I did this partially correct though, because I used soapy water on them... the water just wasn't hot lol.
« Reply #18 on: April 28, 2010, 11:55:45 PM »
did brake pad check before it went for inspection. put that spray on disk quiet stuff on, so far after week no squeaking. shims deff help. my friend put some kinda grease on rear pads and they didnt sweack, i think great works better then spray on stuff
« Reply #19 on: April 29, 2010, 01:04:33 AM »
Quote from: "AV6NHBP6SPD"
Do you spray the disc quiet stuff right on the rotors?
« Reply #20 on: April 29, 2010, 09:24:50 AM »
no, you should never spray those
i sprayed it on back of pad where it contacts caliper and calipers themself where it contacts the pad, i did spray under shims as well
« Reply #21 on: April 30, 2010, 02:43:00 AM »
That's what I thought... just wanted to make sure.
Pages: « First 1 [2]   Go Up
