November 06, 2026, 10:15:17 PM
594
595
Topic: What did you do to your Gen7 today? (Read 3817562 times)
Reply #8910 on:
June 17, 2017, 01:52:46 PM »
Replaced my master window switch, and then programmed the lock portion of the key fob. Put the euro-r cubby in. A good solution for the time being until I can figure out what I'm doing with my dash.
Sent from my SM-N920V using Tapatalk
Reply #8911 on:
July 06, 2017, 10:47:23 AM »
Ordered a new passenger window motor online last night, and some connectors for my rear deck speakers.
Reply #8912 on:
July 08, 2017, 07:46:12 PM »
Replaced my passenger window motor!!
Reply #8913 on:
July 15, 2017, 01:28:45 AM »
Finally put my lip on
Reply #8914 on:
July 31, 2017, 10:19:20 PM »
Sold the old girl...
Reply #8915 on:
July 31, 2017, 11:04:20 PM »
Gave it a hand wash.
Reply #8916 on:
August 01, 2017, 01:08:57 PM »
Walked past it and sighed.
Reply #8917 on:
August 04, 2017, 12:45:01 AM »
have my old turbo kit sitting in the garage. The new owner let me take her out for a spin... It's so slow without the turbo
Reply #8918 on:
August 26, 2017, 05:34:29 PM »
Tire rotation, clean the inside of the windows and refinished my headlights. Then I found that one of the Bezels on the retros is starting to fall off. Guess it's finally time to fix them
Reply #8919 on:
August 30, 2017, 02:14:25 PM »
Got some parts in and started working on rebuilding my transmission again.
Reply #8920 on:
September 01, 2017, 07:17:30 AM »
How many transmission rebuilds are you on now?
Reply #8921 on:
September 01, 2017, 11:35:51 AM »
I think I'm on like #7 or #8. This is the 6th time I've had to tear it down with this motor set up. Granted, the first 2 were stock transmissions that I destroyed. The 3rd time was because I had too much power in it on a stock gear (6th) and destroyed it trying to pass someone on the freeway at 1/2 throttle. The 4th time was because I didn't find damage to the synchros the previous time I had it open, so I had to fix that. The 5th time I had it open it was because I damaged my OEM final drive. This 6th time was completely my mistake. I didn't torque down the drain bolt, it backed out and dumped all the tranny fluid when I was driving it and the bearings overheated and self destructed.
Reply #8922 on:
September 23, 2017, 12:29:04 AM »
So quiet..... I was thinking bout supercharging my crv since my wife took over the civic
Reply #8923 on:
September 23, 2017, 08:17:08 AM »
That should be interesting Ken.
Took the CRV in for her 2nd oil change and whatever else is due at 16k miles.
Reply #8924 on:
November 05, 2017, 05:06:39 PM »
Quote from: Nit3h4wk C0uP3 on June 17, 2017, 01:52:46 PM
...uuUgh that Euro-R cubby is a beauty
594
595
