September 28, 2026, 07:27:22 PM
581
582
583
584
Topic: What did you do to your Gen7 today? (Read 3745571 times)
0 Members and 17 Guests are viewing this topic.
Reply #8715 on:
June 21, 2016, 09:26:29 AM »
I figured as much, but it looked different, so I thought I would give it a shot
Reply #8716 on:
June 21, 2016, 10:41:52 AM »
You could always move the battery to the trunk. Depending on how much you really wanted to use that intake.
Reply #8717 on:
June 21, 2016, 08:23:17 PM »
Custom intake and get the aluminum sections hydro dip to match the rest of the engine bay
Had to replace the pads on the rear of the RDX. Also, drained the some of the brake fluid while i was changing the pads and cleaned out the reservoir and strainer a little.
Reply #8718 on:
June 22, 2016, 03:35:56 PM »
Took the car for an oil change and a checkup. Have to replace my oil pan soon
Reply #8719 on:
June 22, 2016, 10:26:26 PM »
Tore down my gears and found some damage on the synchro hubs and synchros.
5/6 synchro hub
3/4 synchro hub
One of my chewed up synchros
Reply #8720 on:
June 23, 2016, 08:20:17 AM »
You call that "some" damage? I'd call that fucked but mostly because I like using "colorful" language.
Reply #8721 on:
June 23, 2016, 09:57:12 AM »
Damnnnn. Too much torque?
Reply #8722 on:
June 23, 2016, 10:09:36 AM »
Too much torque in a heavy car with traction.
I'll get it all lined out soon enough.
Reply #8723 on:
June 23, 2016, 01:51:00 PM »
Glad to see this setback hasn't deterred you.
Reply #8724 on:
June 23, 2016, 03:34:25 PM »
I have plenty of spare transmission parts at this point. All I really needed was to buy two new single cone synchros. I'm ditching the Gearspeed synchros and going back to OEM.
Reply #8725 on:
June 26, 2016, 05:47:19 PM »
Street tuning the turbo accord :p getting around 9.5 psi after boost creep. It was only suppose to see 6 or 7 psi but shit happened. So I am just rolling with it.
Reply #8726 on:
June 26, 2016, 07:55:57 PM »
Yesterday I cleaned and reassembled the countershaft, then cleaned off all the mainshaft components. Just waiting on some synchros to arrive and then I can get it all back together.
Today I got my fuel cooler mounted and ran the lines. I have to wait until I get my motor back in to test for leaks with the new fuel lines.
Quote from: CrackerTeg on June 23, 2016, 08:20:17 AM
Yeah, that's just "some damage". This is what "fucked" looks like.
Reply #8727 on:
June 27, 2016, 12:16:27 PM »
Fair point.
Reply #8728 on:
June 28, 2016, 06:23:50 PM »
Did some investigating before last weekend after my fuel line started leaking again. I found that during a cold start the pressure was around 60psi tho it was set at 50psi and this was when it would leak until the car gets up to temp and the pressure would drop. It's in the AN -6 hose to female 90* fitting. Now I'm leaning towards going back to my stock fuel setup being that I'm only running 50% duty cycle on the 410cc injectors. Or should I just replace the fitting and give it another shot?
What you think Tim?
Edit: Paul's going to make a new line and ship it out to me so I can send him back this one for him to see what failed.
Last Edit: June 28, 2016, 08:49:29 PM by Rich01
Reply #8729 on:
June 28, 2016, 09:31:33 PM »
Fittings can fail time to time. I had a brand new Earl's fitting start leaking on me. If you have a vice, you can always get the clamps and make your own hoses. Best investment I've ever made, considering how much AN line I have running through the Accord now.
581
582
583
584
