September 28, 2026, 07:40:34 PM
Pages: « First < Previous 1 ... 582 583 [584] 585 586 ... 596 Next > Last »   Go Down
Author Topic: What did you do to your Gen7 today?  (Read 3745594 times)
« Reply #8745 on: July 06, 2016, 09:36:16 PM »
Man, the Good Will is going to become bone dry from all the new pants I keep buying after seeing your pics, Tim. Are those multiple crankcase vent hoses on the valve cover? I don't recall seeing so many, but it has been a year or so since I've had the Accord, so my memory could be foggy.
Yes.  A lot of high hp guys running a lot of boost usually run multiple vent hoses.  I had -10 an fittings welded on to the valve cover.  I ditched the PCV on the water pump housing and blocked the port because I couldn't run a hose off of it.  My intake manifold kind of gets in the way.  Instead, I drilled and tapped the side of it, so it still vents with no restriction.  Right now, they all vent to the atmosphere, but I want to get a catch can/breather box in the future when the funds are available.
Pure sex.
Thanks Jer.
soo clean!!
Any 0 gauge wires that you guys recommend?
Street Wires stuff is pretty good.
http://www.parts-express.com/streetwires-zn3-050r-zeronoise-3-series-1-0-awg-power-cable-red-1-ft--100-9324
http://www.parts-express.com/streetwires-zn3-050blk-zeronoise-3-series-1-0-awg-power-cable-black-1-ft--100-9326
Good luck this time around Tim. Hope you can at least enjoy it for a while this time.
My replacement fuel line was shipped today.
I'm pretty sure I took care of the issues in the transmission.  I tore it down completely and went through all the gears and found more damage than I thought there was.  The new tune is going to pull out a lot of power out in 5th and 6th gears so I don't bust them.  That's until I can afford to get some custom gears cut.
Good luck with your fuel line.  I actually just replaced one of the fittings on my fuel line today.
« Reply #8746 on: July 08, 2016, 08:46:35 AM »
is that a satin silver?
It is indeed. Way I figure, if the original color is called satin silver, make the fucking car actually have the correct color.
« Reply #8747 on: July 08, 2016, 10:02:08 PM »
Noticed a puff of white smoke coming out of the Subaru upon start up. Yay.
« Reply #8748 on: July 09, 2016, 09:55:38 AM »
Does it go away when it warms up?
« Reply #8749 on: July 09, 2016, 10:32:01 AM »
Yes it goes away. I think it's a small oil leak. Been talking with 603 down the street. Hopefully taking it in next week. Which means more quality time with the Accord Smiley.
« Reply #8750 on: July 09, 2016, 09:44:43 PM »
I thought the subbie wad only for winter?  Smiley
Fuel line and PS pump replaced. All seem to be holding up right now. Did a log also and AFR seem to be on point at WOT.
« Last Edit: July 09, 2016, 09:46:22 PM by Rich01 » Logged
« Reply #8751 on: July 09, 2016, 10:39:16 PM »
It's probably just condensation in the exhaust. If it goes away, I wouldn't worry about it too much.
Glad to hear it's better.
« Reply #8752 on: July 12, 2016, 09:54:43 AM »
Booked my tuning appointment for next week.
[ChaosweaveR]
Hellastock
[ChaosweaveR] pfffft.
« Reply #8753 on: July 13, 2016, 08:19:31 AM »
Bought a starter and intake manifold gasket off rock auto.
>_> yay
2005 CM7: EX-L, K24A4, five speed auto
I'm boring, guys. I like function over form. :c
« Reply #8754 on: July 13, 2016, 04:31:03 PM »
Scoping out a new oil pan online to order this weekend.
« Reply #8755 on: July 14, 2016, 09:31:33 AM »
so did you figure out your route?
« Reply #8756 on: July 15, 2016, 09:36:20 AM »
Oil pan ordered Smiley
« Reply #8757 on: July 15, 2016, 10:47:22 AM »
Replaced my hall effect TPS with an OEM one yesterday to fix my low throttle "hiccup".
« Reply #8758 on: July 15, 2016, 07:00:10 PM »
Picked this up.
« Reply #8759 on: July 20, 2016, 06:25:57 PM »
Thing is here.
Pages: « First < Previous 1 ... 582 583 [584] 585 586 ... 596 Next > Last »   Go Up
