November 06, 2026, 11:25:07 PM
Pages: « First < Previous 1 ... 575 576 [577] 578 579 ... 596 Next > Last »   Go Down
Author Topic: What did you do to your Gen7 today?  (Read 3817723 times)
« Reply #8640 on: May 04, 2016, 09:53:35 AM »
Ooohhhh shaved.
« Reply #8641 on: May 04, 2016, 10:09:30 AM »
Not bad for a DIY if I do say so myself.
« Reply #8642 on: May 04, 2016, 09:23:32 PM »
Replace fuel pump strainer
« Reply #8643 on: May 04, 2016, 11:06:28 PM »
More of the same for me.  Just ordered more parts that I cannot afford.
I'd like to know more about how you did yours.
« Reply #8644 on: May 05, 2016, 12:21:30 AM »
Took off the moldings, popped out the clips, welded on small metal pieces I fed from inside the door panels, a little filler to smooth things over, prime and paint.
I wasn't going for absolutely perfect as I have more things planned but for a little bit of time and not much invested, it does the job.
« Last Edit: May 05, 2016, 12:24:23 AM by CrackerTeg » Logged
« Reply #8645 on: May 05, 2016, 06:41:15 AM »
Looks good Z. Any bondo after welding?
I may be doing a little sanding and priming soon so I can safe on an Auoflex coatings job.
« Reply #8646 on: May 05, 2016, 09:18:22 AM »
That's what I meant by filler Rich. The part that sucks though is in certain angles, you can barely see where the clips used to go. Maybe I sanded too far when I was smoothing out the primer and maybe the paint I laid down is just real thin. Either way, it's temporary until I can find some time to continue what I started a couple weeks ago.
« Reply #8647 on: May 05, 2016, 11:22:20 AM »
A lot of times, the filler material will shrink a little bit and cause that. If you look at mine at certain angles you can see that too.
« Reply #8648 on: May 05, 2016, 11:33:35 AM »
Well that makes sense.
« Reply #8649 on: May 05, 2016, 01:15:43 PM »
Mine was done with a slightly different method, which I kind of question the integrity of it because the guy didn't seem to want to do the work to weld anything.
« Reply #8650 on: May 05, 2016, 07:12:59 PM »
Oh, I didn't see that you mentioned filler.
« Reply #8651 on: May 05, 2016, 11:09:41 PM »
that is some clean body work.
Bought some more shit for the turbo build.. Turns out the diaphragm was ripped on the waste gate... So I guess I was lucky to catch it before it goes on and waste money on tuning.
« Reply #8652 on: May 07, 2016, 12:00:14 PM »
Fender garnishes came back today from Maine Coast Customs.
« Reply #8653 on: May 08, 2016, 02:15:27 AM »
bought a spare turbo CHRA as back up.
« Reply #8654 on: May 08, 2016, 02:00:19 PM »
Replaced my front bumper quick release clips with something far cleaner and finally shaved my rear H.
Pages: « First < Previous 1 ... 575 576 [577] 578 579 ... 596 Next > Last »   Go Up
