November 06, 2026, 10:15:25 PM
Pages: « First < Previous 1 ... 574 575 [576] 577 578 ... 596 Next > Last »   Go Down
Author Topic: What did you do to your Gen7 today?  (Read 3817563 times)
neoryan7
neoryan7 pfffft.
« Reply #8625 on: April 23, 2016, 07:50:31 PM »
Your in NH?
I am, just moved here about 6 months ago. You in NH?
« Reply #8626 on: April 23, 2016, 09:38:47 PM »
I am! The southern part! You on Facebook?
Today i dynamated the roof, and did some more feather work on my visors and pillars.
neoryan7
neoryan7 pfffft.
« Reply #8627 on: April 23, 2016, 10:14:15 PM »
I'm in lebanon. Where are you? Nice, need to sound deaden my car as well.
« Last Edit: April 23, 2016, 10:19:32 PM by neoryan7 » Logged
« Reply #8628 on: April 26, 2016, 09:14:18 PM »
Mailed my fender garnishes to be dipped.
« Reply #8629 on: April 26, 2016, 09:28:28 PM »
Replaced APP sensor, nice to not have to fight with the pedal  anymore. Will be doing a log tomorrow. Have a feeling I'll be reverting back to the cal I've been running.
« Reply #8630 on: April 26, 2016, 11:00:56 PM »
Spent yesterday and today finishing up the wiring to the pumps and flex fuel sensor. Also got most of the plumbing finished for the fuel system. I'm just waiting for 2 90° fittings to come in and the fuel system will be buttoned up under the car.
I also got my KPro v4 update back from Hondata today. So I swapped the board back into my modified ECU and will be wiring up the flex fuel sensor to it. Going to try and see if I can easily wire my wideband, oil pressure and boost gauges into my KPro too. After that, I may try and add some water temperature sensors to my water to air system to keep an eye on the water temps.
« Reply #8631 on: April 27, 2016, 12:58:50 PM »
Look at all those pretty braided things!
Ordered some stainless steel brake lines for the front.
« Reply #8632 on: April 27, 2016, 02:41:47 PM »
that soo pretty Smiley Hondata FTW
« Reply #8633 on: April 27, 2016, 05:03:02 PM »
I spent some time mounting my circuit breakers for my fuel pumps.  Going to try and get some upper mounting brackets made for my new radiator fabricated tonight.
Yes, I probably have about $1500 in just AN lines and fittings.  Between my fuel system and after cooler system, there's some serious money into it all.
Yes.  I'm happy about the upgrade options with KPro v4.  I can use a flex fuel sensor, it has digital inputs and analog inputs, plus it has bluetooth connectivity so I can monitor from my phone.  I'm considering the injector driver for a second set of injectors down the road.
« Reply #8634 on: April 29, 2016, 07:40:39 PM »
Got hit by a bird today on the highway. What the hell?
« Reply #8635 on: April 30, 2016, 07:43:32 PM »
Ripped off my side moldings. Will fill the holes tomorrow.
« Reply #8636 on: May 02, 2016, 09:50:27 AM »
Side moldings officially shaved. Just need to throw down some paint to finish the job. Shaving the rear Honda badge next.
« Reply #8637 on: May 02, 2016, 01:05:25 PM »
Talking to another shop about my interior..
« Reply #8638 on: May 03, 2016, 12:06:07 AM »
Got my CAN converter updated with new firmware to hopefully correct my speedometer. I guess the math was off from before because my speedo was reading about 5% faster.
« Reply #8639 on: May 03, 2016, 09:32:40 PM »
This happened
Pages: « First < Previous 1 ... 574 575 [576] 577 578 ... 596 Next > Last »   Go Up
