September 02, 2026, 03:50:48 PM
572
573
574
575
Topic: What did you do to your Gen7 today? (Read 3689279 times)
Reply #8580 on:
April 11, 2016, 06:03:12 PM »
Drove down to my welder and picked up my new radiator and a few other small pieces. Hoping to get 6th gear replaced in my transmission and have it all buttoned up tomorrow if the weather is nice enough.
Reply #8581 on:
April 11, 2016, 07:38:07 PM »
good-ridge is going to send me some new SS lines. A+ customer service
Reply #8582 on:
April 13, 2016, 08:07:27 PM »
Bumped my fan temps up to 190on and 170off. Also, been priming the fuel a couple times before starting. So far so good. Now onto diagnosing a low rpm surge/hesitation which has resurfaced over the last few weeks.
Reply #8583 on:
April 13, 2016, 10:29:42 PM »
Glad to hear that has helped Rich. The surge in idle can be due to a vacuum leak. I had a wonky idle on my car too. When I pulled the blower off, I found a crack on the bottom of the plenum creating a vacuum leak. Check everything on your intake manifold and make sure you're not missing something. It's tough to find a leak, but you should be able to with smoke or a propane torch (unlit). Because you have DBW, it's definitely not the IACV.
I was able to relocate my alternator down about 1/2" and get the clearance I needed with my intake manifold plenum. I also shipped off my #5 cam tower to get modified for an oiling upgrade modification. Tomorrow I will need to pull my oil pan to replace my timing chain crank gear with an upgraded keyed version. I guess some of them have been prone to breaking in high hp set ups. Hopefully I'll have time to dig in to my transmission and replace 6th gear.
Reply #8584 on:
April 14, 2016, 04:38:25 PM »
Did some grinding today to clearance from my plenum from my water pump housing and so I could get rid of that stupid intake manifold thermal gasket. This should be helpful in making more power now that the injectors will be properly spaced from the intake valves.
I also worked on cleaning a few things up on my blower set up and should be ready to pull my oil pan to swap my timing chain crank gear.
Reply #8585 on:
April 14, 2016, 05:27:18 PM »
Ordered some jack stands, and detailing/cleaning products.
Reply #8586 on:
April 16, 2016, 12:20:24 AM »
Pulled off my oil pan and cleaned it out. I have the Moroso oil pan, and it has a top baffle/second windage tray. The hole in that for the dip stick to pass through was too small and it would be difficult to get the dip stick in. I pulled that baffle off and enlarged the hole. I also pulled off my oil pump and replaced my timing chain crank gear with the TD Autowerkes upgraded keyed gear. My L19 head studs and Radium fuel filter also showed up today. Everything is slowly coming back together.
Reply #8587 on:
April 16, 2016, 04:47:20 PM »
Got the rest of the Works on, put my driver's side window visor back on, and tried to remove the rear seat belts, but #stubbornbolts then I went for a wash.
Reply #8588 on:
April 17, 2016, 09:37:49 PM »
Quote from: timot_one on April 13, 2016, 10:29:42 PM
I would think a leak would produce a CEL. Also my idle is fine its just driving. I'm constantly fighting to keep throttle constant. I saw in a log on the highway where the TPS% went from 23% to 16%.
This weekend I pulled the IM and cleaned it out with some TB cleaner. Saw a little oil mist in there. Routine cleaning of the EGR valve. Also gave her a much needed wash and put the Works back on.
Reply #8589 on:
April 17, 2016, 10:20:33 PM »
^ hey rich I got a question. I might have the issue as you. So for some reason my car won't start with the clutch in *even with the clutch switch bypass*. It just acts like you didn't push the clutch in and just won't turn over. It is random and I just have to pull the key out, and lock the door and then try again.
Reply #8590 on:
April 18, 2016, 06:42:45 AM »
Ken, mine always turn over. We're pretty sure it's because I have a return line that over time all the fuel runs back to the tank from the rails. This requires priming a couple times before starting. So far it's been working.
Do you at least hear a tick when this happens...
Reply #8591 on:
April 18, 2016, 08:55:39 AM »
I do not hear a tick when it does not want to start. The best way to describe it is when you try to turn the car without pressing the clutch. I have already ruled out alternator and battery since those were all changed out.
It is also not the clutch switch because I put a paperclip to jump the signal.
I tweaked my rear camber today. So hopefully that will help with doing the toe adjustment. -23* toe is just awful on the tires
Last Edit: April 18, 2016, 04:26:03 PM by thisaznboi88
Reply #8592 on:
April 18, 2016, 08:28:27 PM »
That's a weird one Ken.
Reply #8593 on:
April 19, 2016, 11:40:06 AM »
Scheduled an appointment for an alignment
Reply #8594 on:
April 19, 2016, 12:53:48 PM »
Okay I think it is the starter that is sticking again. I turned the key to day and click no start. Hit it with a wench and it started right up. So looks like I need to do a warranty claim on it.
Fixed the wife CRV a/c. I was missing an O-ring that was why it was leaking freon. Now it holds pressure.
Last Edit: April 19, 2016, 07:15:06 PM by thisaznboi88
572
573
574
575
