September 02, 2026, 02:45:06 PM
570
571
572
573
Topic: What did you do to your Gen7 today? (Read 3689209 times)
Reply #8550 on:
March 28, 2016, 07:05:48 PM »
I also ordered some dynamat, and I'm working on getting the old adhesive off my driver's side visor so I can put it back on.
Reply #8551 on:
March 28, 2016, 08:40:33 PM »
finally found the A/c leak in the CRV after using some UV dye. I think it might be the oring. So I am just going to order one from honda.
Reply #8552 on:
March 30, 2016, 04:20:55 PM »
adjusted my rear camber kit so that it is not -2.6. Looks to be around -1.8 now after a quick drive to let it settle.
Reply #8553 on:
March 30, 2016, 08:57:25 PM »
Valve adjustment, spark plugs, brake stuffs, new valve cover, and replaced a stripped lug nut at Wicked in Londonderry.
Reply #8554 on:
March 31, 2016, 08:40:01 AM »
Didn't work on the Accord, but replaced a busted axle in the Fit yesterday.
Today I'll be dropping off my Koyo Si radiator and upper coolant passage fill neck to get modified to fit my car. Also having the -6 fitting on my aftercooler replaced because the fittings are all galled up.
Reply #8555 on:
March 31, 2016, 01:54:40 PM »
Wow that fit loves to break axles
Reply #8556 on:
March 31, 2016, 02:14:25 PM »
Yeah. It was the other side this time. Water gets under the rubber vibration damper on the axle and over time is corrodes and weakens the axle. Both axles are new, so it should last another 200k.
Reply #8557 on:
March 31, 2016, 09:27:17 PM »
bought a new oil pan. Hopefully, the oil return bung will be welded in the right spot this time...
Reply #8558 on:
April 01, 2016, 06:29:30 AM »
Ordered a Mishimoto low temp thermostat.
Reply #8559 on:
April 01, 2016, 10:23:05 PM »
Ordered RL Calipers
Reply #8560 on:
April 02, 2016, 07:57:07 PM »
Took the car out of the garage with every intention of putting my summer wheels on. The new jack started leaking and refused to work. (Am I dumb? Or is it broken?) Taking it to harbor freight this week. So I got one wheel on! Lol I also changed the air cabin filter in the Impreza.
Reply #8561 on:
April 02, 2016, 08:05:55 PM »
It could have a bad deal of its leaking oil. Since you just got it, take it back and have it replaced.
Reply #8562 on:
April 05, 2016, 12:29:29 PM »
replaced my AGU fuse with ANL. Hopefully they wont suck as much.
Reply #8563 on:
April 05, 2016, 02:01:33 PM »
I've been using circuit breakers and haven't looked back.
Reply #8564 on:
April 05, 2016, 04:33:54 PM »
^ I wish I knew about those the first time around. Save me a ton of money instead of buying fuses
570
571
572
573
